Doktor
Sve objavljeno od Doktor
  1. . . . i za kraj : http://stereonomono.blogspot.rs/2016/01/quad-306.html " The Quad 306 is entirely compatible with the ESL-63 loudspeaker but should not be used with the earlier model which could easily be damaged. " Nadam se da sam pomogao.
  2. . . . http://www.audio-nirvana.com/pag_eng/amp4quad.htm In addition to the problems mentioned above, the original Quad speaker has mediocre efficiency ( approximately 84 db/Watt ) and limited power handling : Original Quads will flash up immediately when the voltage on the input terminal exceeds 33 Volt (peak-peak). From 1990 onwards a protection circuit (a diode rectifier bridge) was suggested by Quad-UK, quite similar to that used in the new ESL-63, though it protects here only the treble unit and not the bass panel. Models which include that protection circuitry can be used safely with powerful valve and solid-state amplifiers although long overdrive is not recommended. Generally valve amps are not upset by an awkward load as presented by the ‘57, but many solid-state amplifiers quickly give up in a cloud of smoke. I encountered several solid-state amplifiers that immediately blew up and some of these items damaged the delicate Quad speaker before they died. The biggest crap I ever encountered was the BGW 200 : I had connected it to my Quads as the manufacturer had stated in the manual that model 200 was stable into electrostatic speakers – actually it was not ! Within milliseconds the BGW 200 went into oscillation and killed both treble units. It cost me a fortune to repair both the Quads and the amp. The respected Audio Critic magazine wrote about this amp " This one is a disaster…." How true !
  3. http://quad.hifihaven.com/article:Quad-amplifiers-by-Christian-Steingruber " QUAD 306 (1987- 97) Solid-State Quite a nice amp that was designed for driving the only "dynamic" Quad speaker which was an OEM version of a small Spendor speaker ( similar to the BBC LS3/5A ) and was built by the Spendor company for Quad . It was never designed for driving the original ESL-57, though several owners did so and speak quite good about the match. Maybe it sounded a little "compressed" and "undynamic" but quite nice to the ears. " Btw, ima toga jos po forumima, blogovima . . .
  4. I ja se jos slabije razumem u sve ostalo sto si napisao. Kao sto rekoh, svojevremeno sam prosledio @paja959 to pisanije, kada nadjem prosledicu i ovde. Malo strpljenja.
  5. ^ http://quadrevisionspot.blogspot.rs/2009/06/impedance-of-quad-esls-and-monoblocks.html
  6. ^ Pricasmo o tome vec. Na zalost, Quad 34/306 je combo za njihove dinamicke male kutije. Quad 11L i 12L. Za Quad ESL 63 je tada predvidjen i napravljen combo 44/405. Grejanje samog 306 je, na zalost, vezano za nekompatibilnost sa ESL 63.
  7. ^ Upravo tako. I jos onaj mali kond sto si mu savetovao onomad. Fina sprava definitivno.
  8. Kao neko ko nikada i nije ozbiljno "zagazio u digitalne vode " mogu slobodno reci da je veoma prijatno iznenadjenje za mene juce bio i DAC Yang. Kod Groznog sam se naslusao vise desetina DAC-ova cenovnog razreda od . . . xxx, do . . . . xxx, ali nikada do sada u njegovom sistemu nisam cuo ovako kvalitetno procesuiranje bitova sa HD-a. Grozni, urgiracu kod Mr. Neskora po pitanju ovog Yang-a. Greota bi bilo da to ode od tebe, a meni isto lepo jer vise nece biti DAC "klashova" kod tebe, pa mora da se pazljivo slusa, poredi, debatuje, a vinili da skupljaju prashinu, a ne da im bude mesto na tanjiru kako Bog zapoveda.
  9. Sjajno popodne. Lazar Bros. doneli pozitivnu energiju iz Zr. LP lot od "Brace" - Cuo sjajnu mladu fado pevacicu, notirao za wanted vinil listu. Gisela Joao. Po ko zna koji put potvrdio sebi da ruska "Melodia" LP izdanja zvuce vrhunski/ Igor Ojstrah i Paganinijeva kaprica. Pijanistkinja Natalija Zercalova se pokazala kao vanserijski muzicki saradnik Igoru. Audio sistem balansiran, prijatan, realistican. Bryston/Cotter je poseban SUT. Ezoterija u pravom smislu reci. @grozni - veliko Thnx na gostoprimstvu.
  10. @Woland, fenomenalan ovaj danasnji lot LP-a koji si ovde postovao. Sarker - odlican izbor ( cak mi je ova prva LP sa Sumanovim i Laloovim koncertima draza emotivno od njegovih "surovo dobrih" Bahovih svita ). A tek Haden & Meteni ( moj favorit je numera " The Moon Is A Harsh Mistress " koju su snimili Radka Toneff i Steve Dobrogosz na albumu "Fairytales" ). Resio si me ono bar "slatkih muka" sta da ponesem kada sledeci put gostujem kod tebe. Naime, slusacemo ovo ako nemas nista protiv.
  11. Ovako od sabajle . . . . 'jutro
  12. ^ Nije ona looda, vec kompozitor. Mozart je osvedoceni "terorista" zenskih vokala. Jedan od eklatantnih primera je i "Exultate Jubilate" ( fenomenalna Cecilia Bartoli ). Sto se tice "Kraljice noci" iz " Carobne frule" za mene je najbolja i neponovljiva Lucia Popp
  13. ^ Vidim, pronalazis ove dobre pijaniste iz Italije. Alessandro Stella je prakticno vec resident u Luganu i projektima Marte Argeric. Tipican predstavnik italijanske skole pijanizma ( muzicka akademija Santa Cecillia u Rimu koja definitivno daje pecat svim svojim pitomcima ). Medjutim, izuzetno mi je drago da si pronasao Alessandru Celletti koja je radila sa Roedeliusom, zivom legendom eksperimentalne muzike. Sigurno grabis ka krautrock-u i belinskoj skoli za elektronsku muziku.
  14. ^ E, ako si ovo rek'o. Kao neko koga bas pa "zabole" za kineske jeftine iteme - samo napred !
  15. Sta s njega ? S kim, . . . s cim . . . i zbog za cega ? Prosvetli, . . . . obasjaj . . . . sem sto sam procitao negde ( ovde li to beshe ? ) da zvuci vrhunski. Nego . . . . . . . ovo sam slusao na jednoj kremaciji pre jedno 5-6 godina. Odlicno izvodjenje. Preporuka.
  16. Nece skoro Bozic, ali tako mi "doslo". 'ebo 33/303 u problemu. Nesam izdrz'o. "Pegla" 211 za svaku paru. Jos i izgleda i svetli kao "lampion". Doduse na +33 u hladu i nije neka dobit. Zato je klima "Keva".
  17. ^ Da, ali za taj " biznis " sto ti ovde primenjujes postoji PM ili drugi nacin komunikacije. Telefon, npr. U najmanju ruku, pretera ga ovim tvojim potpitanjima i komentarima. @stein, oprosti na ovom off-u. Ti bar mozes kao moderator ova sva suvisna naklapanja skloniti na "smetliste". Da poentiram. Tvoja prodaja Soltanus kompleta je apsolutni bargain za onoga ko to moze sebi priustiti.
  18. ^ Dakle, Wolly . . . . . neverovatno. Ovako dobru kolekcijiju "Requiem"-a nisam video ni kod mog dragog prijatelja Crva. Dva Telefunken izdanja koja imaju solidnu novcanu vrednost, a i kao da su zlatne poluge jer im cena raste iz meseca u mesec. To je najmanje bitno ovde. Dirigentni, solisti, orkestri . . . . sam vrh i ezoterija. Dubok naklon za ovaj trenutni set u tvome vlasnistvu. Nikako nemoj stati. Melodija i Opus ( naravno i Supraphon, ne spomenuh ga onomad ) pod must.
  19. ^ Kako drugacije, a da ne bude prihvaceno uz obostrano zadovoljstvo. Sistem je spreman ( varijanta A - SET 211, varijanta B - 33/303 ). Kada dodjes u nase krajeve, slusamo obe varijante.
  20. Jos jedan korak napravljen. Veliko hvala @neskor-u na pomoci oko ovih zvucnickih konektora koji su idealni za Quad uredjaje. Meni kompletirano iz njegovih rezervi, a porucen vec isto vece novi komplet sa ebay-a.
  21. ^ Fozgen
  22. Pa izbrisi neke stare konverzacije i poruke iz tvog mailbox-a. Evo, ni ja ne mogu da ti posaljem jedan vazan pm. Ocigledno da ti je popunjen personalni mailbox ovde.
  23. Nemam pojma ? Sada sam pregledao neke moje "Melodije". Vidim da ih ima i sa crnim papirom, srebrna slova. Btw, gratz na LP-u jos 1 x, obzirom da ima sada trenutno na Discogs-u samo 1 komad u Spaniji i to za tricavih 79 eura. https://www.discogs.com/S-Rachmaninov-Yevgeni-Svetlanov-Leonid-Kogan-Fedor-Luzanov-Trio-2-For-Piano-Violin-And-Cello-In-D-Mi/release/8190458 Te zato .
  24. @Woland Ma ne. To su svojevremeno dobijali na "tackice" svaki mesec za u potrosacku korpu. Btw, koje je boje papir na LP-u ? Crveni, teget, prljavo belo-zuti ?
  25. ^ Da, da . . . to je ona dobitna kombinacija : Svetlanov & Kogan & Luzanov.
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 248 Gosta (Pogledaj celu listu)
    453.7k
