generg
1 Pratilac
O generg
  • Rođendan 04/11/1947
Informacije Profila
  • Pol:
    Muško
  • Interesovanja:
    Audio Diy, Tai Chi Chuan
  • Zemlja:
    Germany
Skorašnji posetioci profila
generg's Achievements
Interesuje se
Interesuje se (5/9)
0
Forumska reputacija
  1. I do not give up to get my J2 clone nearer or on similar level than the original I have still for comparison reasons...... my newest try (a recommendation from the master himself) - omit the source resistor of the lower SemiSouth -loosen the feedback by choosing a value higher than 100k, I took for a try simply 150k you get of course more gain, about 6db more, so you may have a small hum problem and readjust some cables.... the sound is not the same like the original but on the same level........a bit more body I already liked with the MosFet inputstage......and still more engaged than the original. But I am afraid, I will stay the only one who tried this.... for exact and authentic people here comes the link to Nelsons statement starting with the words "Lord of the SIT sez:" http://www.diyaudio....tml#post2952893 and one link how to use two unmatched J109 in the J2 constellation.... http://www.diyaudio....tml#post3108123 good luck!
  2. Yes, thank you for the reminder! The 9610 is set to 30mA in Pumpkin and I would set the the two J313 to 20mA, so only ten for each......I will hear....
  3. I just remember that I changed two years ago after recommendation of ZM the 9610 in Pumpkin against the J313 and the difference was very clear, but at that time I preferred the "mosfet bloom" as Zen Mod calls it....the sound was clearly more detailed and I think it will come nearer to the 2J109....but I cannot try today, my wife occupies the room with the amp learning for an examination at university (Chinese)......so I hope I can soon communicate with the myriads of Pass cloners in China....
  4. Pa is of course in the sweet spot......me not....thanks Zen Mod
  5. thanks Sipi for valuable hints.... and I take care of the panorama! :oke:and I will give the 2j313 a try instead of old 9610
  6. yes 7,5mA per side.....and I confess "origigi"
  7. Just for fun I changed today the one 2SJ109 BL in the BJ2 to a pair of closely matched 9610. (from diytech 0,01V), Zm will laugh, "change your lousy BJ2 back to an Aleph 3"My intention was to drive them with the 20mA the two 2SJ109 or four J74 get normally, and I was eager to hear if the much higher transconductance would do something to the sound.sound is (as often remarked) darker, a bit more punch in the lower bass, but much, much less detailed and airy than the J-Jfets.So back to one 2SJ109 per channel again.....Can anybody comment if going to 15mA with one 2SJ109 device would be to much, Euvl did even heatsinking the 2SJ109 in former times when they were still more in use....
  8. I wish you could hear it!
  9. update for all BJ2 fans and builders.... I occupied over 6 weeks with the sound of my BJ2 compared to an original FW J2........ it was a hard time...... I tried all.........................................................................................! I even ordered a pair of R125 because the FW J2 had them, from a guy at Miami, but, no the input was the place! To make it very short............................ to come near to 80% of the lovely sound of J2 original....... I had to take one pair of 2SJ109 in the input. ( I know it is a compromise) Every try to set in, even very closely matched quadrupels of J74, and not so closely matched two 2SJ109 in parallel, (I spend some money to buy them in Germany and I had to sent back some because they were sold defect.....) ................gave a more muddy sound. So if you want to experiment with your BJ2 and you still have a pair of good old 2SJ109 give it a try. After six weeks it is a happy day today!
  10. Hi Aleksandar, very fine big Rifa caps! and what is the use of the small resistors near the CL60 thermistors? I am satiesfied that even you make the big holes in part one with many small holes with the drilling machine.....!
  11. o.k. I bridged the 0R68 resistors and ....now in my system the sound gets even more precise but a bit too hard and less "panoramique"so I returned to the former constellation..incredible what o.34 Ohm changes.......!next tries come......
  12. every suggestion welcomeI will try and hear....
  13. O.K. thank you both for your explanations and hints.......! :)and I am afraid my cd-player is also pentode like so I have no chance......... :Pmaybe one point is important, the Mufollower is normally more push pull than single ended.....
  14. But may be the SJEP120r100 is also triodish in the region of 1-2A .....So I ask myself why did Nelson develop his own SIT?
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 33 Gosta (Pogledaj celu listu)
    449.5k
    markot
    markot
