Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. @ Notax :podelu platneno-gumeno sam dao kao info za cisto vizuelno prepoznavanje ;naravno da je i spider drugaciji , ako im je gornje vesanje drugacijestoji sto si rekao , i sve je vidljivo iz grafova i T/S
  2. anyway - be happy - input Jfets are still pentode-like ........ so nothing wrong with proper pentode even in output :roflyou remember - M2 isn't so bad amp , even with plain Mosfets in source follower configuration
  3. yes , it is - difference between R100 and R085 is , say , negligible in our field of use .edit - just found that , in a hurry , I mixed SJEP and SJDP .......... when I wrote negligible - I meant on SJEP's , while SJDP are somewhat different :rofl:anyway - you dissmantled source resistor in lower SS source ; with adequate value of resistor (as everything - compromise between one and another goal - load line or xconductance/gain) you'll have more leaned load lines on graph .......... so more triodish to have strictly triodish with still needed xconductance ( without need to alter load lines with resistor or something else )
  4. ninja je mislio na to da K3808(K3809) - driver sa pleated surround - ima oko 10Hz visi Fs od drivera sa gumenim/neoprenskim surroundometo - vidim da je u medjuvremenu i odgovorioono sto je bitno , bar za mene , je to da K3808 ne pati od potrebe za menjanjem surrounda svakih 10-15 godina kao drugi ( i oni sto su "gumenjaci" u stvari nisu , nego je uu pitanju premazani neopren) , zatim ima laksu membranu ( bez ribs ojacanja nazad) ...... sto samo pogoduje .pitanje basa - Tannoyi imaju iznimno mali Qts i relativno veliki Vas ; gumenjaci sa nizim Fs imaju basa vise od ovih sa pleated surr samo u manjim kutijama , dok se u vecim zapreminama ( >200+ litara) to nekako pojednacuje i nema neke velike razlike u F3 izmedju gumenjaka i platnjenjaka naravno da im treba kontrole ...... ali nisu u pitanju toliko watti koliko je u pitanju dinamicki potencijal ( pa i damping faktor) samog pojacala .moze se uslovno napraviti podela na 3 generacije Tannoya :- prvi (black , silver , i prvi gold , bez obzira kako im je sifra tipa) - svi sa AlNiCo magnetom , su najmanjih elektricnih snaga , manjih kretnih masa; pepperpot horna- drugi - gold , K serija - svi sa keramickim magnetima - vece snage , malo nize efikasnosti i vece mase kretnih magneta ; redigovana ( kraca - zbog manje duzine keramickog magneta ) pepperpot horna-treci - moderni sa tulip hornom/waveguide ; jos vece snage , so-so efikasnost , jos vece kretne mase ; tulip horna podrazumeva i HF jedinicu koja je , recimo , zasebna ...... i ima dedicated magnetisplativa nabavka je drugi tip - K serija , jer nema rizika od izduvanog AlNiCo magneta , a od tih par tipova za mene licno K3808 je optimum ....... kompromisa
  5. Generg and Sipi - regarding Shade of SSluths -just a quickie , don't have more time now : http://www.diyaudio....tml#post2955803 in short - there is no need
  6. nice to read you herecan you please just sketch that arrangement ( without rest of circ ) ;I'm not sure that I'm following youin case that you don't have time ( Tai Chi etc. hehe) for shrinking usual Generg's sketch , just send it to me
  7. usput - cela ta prica mu dodje hogwash manje ili visedaleko najveci problem kod koax zvucnika je stepen ne-koincidentnosti ta dva izvora , a ne problemi sa refleksijama visokotonskog spektra na izvodnici koju cini sama bas membrana .sto ce reci - eto ga malo zakomplikovali , pa izgledaju drugojacije od drugih ......... a waterfall-a nigde , da pokaze superiornost konstrukcije
  8. ja bi rado bar 10db vise
  9. vidi se da si medicinar , pa nenavik'oDevoni se najbolje maskiraju kaktusomonim od 6-7 cm precnika ; po jedan na svaki Devonihaj!
  10. :rofl:ja ne znam ........ a i sto bih
  11. a clamp sa stegom , na principu srce u sestaru ?
  12. eto - sve sto mogah pomoci , pomogoh - editovao sam naslov iz Villagar u Villager
  13. bem ga - popravljao sam ortaku Gorenje , nekolicinu stvari tokom godina , ali smo za njega imali dokumentaciju , sto pomazeajd nadam se da ces se snaci nekako
  14. uvek mozes da ubacis i buzir , prikljucnicu i pistolj od Gorenjano - ova problematika prevezivanja ne ide bez seme , bar ne ovako daljinskimeni bar slike nista ne govore
  15. su to neki mali Devoni ?
  16. Zen Mod
    BB-BJ2
    a moze i od morske pene .......
  17. pa ne moze da ih spari zbog db/Wjedino da se ide na aktivu , a to nije naveo kao opcijua i moram malko da ga zekim ......... Vix je to
  18. prizovi se pameti ...........
  19. e nek' si nam rek'o !(doslo lepo vreme , moze se polako i iz pelena )
  20. ..... kako vam drago .....
  21. vala basmada - skoro da je i istina - kako Gujica menja raspolozenja ........ danas jesi , sutra nisi:buehehe:
  22. jes , sad ces opet da nadjes nesto , pa ces da se razocaras .......imas coveka cije si Babuske mnogo nafalio ........ a on ce ti i izracunja i smota ovo levom rukompogledaj sta se napolju valja za ihaj novce .........
  23. mlad si , ne beri brigu ......jednog dana napravis surround od koax 15-ki
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 277 Gosta (Pogledaj celu listu)
    454k
    DusanJovanovic
    DusanJovanovic
