41002 -
630
Sve objavljeno od Zen Mod
graphs, 8R load difference to boring regular Il Penitente is - more uniform THD Spectra on all power levels
Now - Il Penitente Il Spettacolo is wakoo iteration with special parts in output stage we can call then Insulated Gate Bastard Transistors ........ made simply by tossing out source resistors of TO220 mosfets, so mosfets are covering just base current of output BJTS here's schm
Ok , that's it ....... Pretty straightforward..... nice SETish THD spectra ....... but wait !! There is also Il Penitente - Il Spettacolo!!!
kao i uvek, lenj da kucam ponovo, pa copy-paste sa Big DiyA: yup, as I said , bad influence of Cyclotron emanation , all the way from Bubba Bob's Davis ...... 'Talian names popping as mushrooms after the rain anyway, what's better to put on pizza than mushrooms ....... So, last one in series of autoformer gain amps (you can call them all - M2 on Mushrooms ) , this one differing on outputs being classic BJT complementary pair, so sorta blasphemy in Papaland ......... he sinned heavily eons ago ....... while my Sin is recent........ Anyway, here's funny diagram, showing nothing else than bunch of multilegged fuses and some nice iron hm, yes, my prototype equipped with first genuine ones I snatched from drawer - 2SA1491/2SC3855 ....... but pretty much any "for Audio amp" complementary pair should work well ........ 2SA1943/2SC5200 , TTA/TTC (newest Toshiba incarnation of 2SA/2SC) rails +/-23V, Iq 1A5 2nd is clearly neg phase, not seen from my gigglywiggly, but I stumbled on nice routine in LTSpice showing just that behavior and didn't yet found reason to doubt it
sprint, orbit, audiopower, takodje prodavnica na cosku brace ribnikar, kod sprinta
Buducnost je GaNFET D klasa pojacala i digitalija!
Zen Mod je odgovorio/la savan's temus u Solid State
nije sija nego vrat konverter uradjen sa strujnom kapacitetom da gura zvucnjak aj se kladimo da moz prepraviti TIG da to radi ....... na stranu sto bi pre trebalo uloziti energiju u malo trazenja koji industrijski uredjaj je vec napravljen za to -
tu ni mis ne prezivljava, kamoli macka -
menscini da sam ja rano ostario, prestao da razmisljam u tim musko-zensko relacijama
pa neki poistovecuju isto sa uvredom......... nebrojeno primera po svim forumima, ne samo tehnickim, po celom svetu ono, kol'ko sam kritika dobio na svoje briljantne ideje, ja sad ne bih pricao ni sam sa sobom ani sa predsobljem........... ene, nije li svrha komunikacije - ucenje .... napredak, usavrsavanje ...... msm. sve to odmah posle zabave ......... -
ne diraj mi Vuleta Vule je u svoj svojoj zaebanciji uvek imao integritet kad god je napravio novi nalog, uradio je to tako da se vremenom vidi da je to on, pa se merge sa starim banovanim i onda jovo nanovo Vule je bio Mrgud u osnovi, nije bio slon u staklarskoj radnji -
da sam je sreo pre 35 godina, zenio bi je, garant
si zaljubiska?
bolji je od BJ2, u svakom slucaju
esi imzenjer ili nisi to je normalno -
imam ja dva ST predajnika od 100W, push-pull sa 4CX250B taman bih mogao D Class, stereo a moderno D klasssss pojacalo kupim da mogu lemim mariniju sa njim -
ima to svoje polje upotrebe .... ne moz turis a klasu diskretno u mobilan ili tablet ili gde vec al mislim, cinjenica da na netu sve sam strucnjak predvidja sta ce da bude ...... pa ga jos zaokruzi onako siroko nasiroko samo svedoci o nesvesti kako funkcionise trziste, kako je podeljeno, kolike su ciljne grupe klasican primer baba i zaba -
well, to je njihov problem
zadnji od ampova sa autoformer gain i Square Law izlaznim stepenom ovaj put - oba izlazna su BJT ne stigoh ga ranije ....... a sad moram jer je jedan fantom poslao pare za full kit, iako je video samo sliku praznih pcbs a kaje se sto je Sinner, sta drugo ...... nisu sitovi i mosfeti u izlazu
Trenutno na sajtu 0 članova, 0 Skrivenih, 231 Gosta (Pogledaj celu listu)
Ukupan broj tema454.2k
