CeeVee
Sve objavljeno od CeeVee
  1. Now that is a teaser....showing a babelfish with SITs....talk about unobtanium...heheheh.
  2. Doing what it was made for.....playing sweet music.....thanks again ZM for this HOT amp
  3. completed and naked.....
  4. the double bridges...and a DUCATI....hope this one performs better then Vale's........
  5. Master ZM, Here is the Beast......Two toroydi 400VA, double MUR 3060 BRIDGES, 120UF TSFHAs per rail/channel bypassed by 40uF DUCATI caps ....aiaiaiaiaiaiaiaiai ........ some building pics:
  6. Great, i'll look for the motor run caps locally, ICAR is difficult to get i think....but i'll look around...thanks again ZM .I'll make another bottom plate and optimize layout for double mono, you bet I'll fit the motor run caps.....:-)
  7. The PSU is pass standard 4x15u TSHA each channel with CL60 from ground to chassis and another one in series with primary. dead quiet.Transformer is Toroidy 400VA , 2 18V secondaries. You think going double mono is better ?....2 300VA transformers ? would really appreciate your input on this, wouldn't mind going for a all tricked out PSU for it, if it gets any better i'm making a pedestal for it .....
  8. ...no all have pics.
  9. innards back...
  10. More BJ2 Porn....
  11. Just so you know what i have to play with the BJ2, from left to right; The Orions 3.4 ( last version with original woofers ), obviously i don't have enough BJ2s to play them with but remain my reference system with an ATI amp ( 12x 60 W ).The little passive speakers i have at the moment to test with, Mordant short 89dB, not in the league of F5 and BJ2 but boy do they sound good !My developing Shiga Clone...plays great but not up to the Shanling on it's right yet, behind that is a Bufallo DAC.Shanling with new discreet IVs, developed with the help of your's trully....ZM, my reference CD player.BJ2 ofcourse and the Orions' Analog processor.......
  12. I tried to make the case do justice to your fantastic work.....but i guess i was a little bit too eager to hear it ....... I was just listening to IZ singing " over the rainbow" ............oh boy , i'm overwhelmed !
  13. ....innards....
  14. Hi guys,My BJ2 is finished, had to adjust a couple of resistors to get alignment but it has run for 3 days and been realigned, stability temp and alignments are fine, it's running at 2A bias, rail voltage 25,4 V Sound is ....................gorgeous, comparing to my F5 it seems to have more definition and "attack" , very well defined bass....voices have been praised by many....i agree, and it's very easy on the ears, no hints of tyring effects. here are some pictures as promised with a huge thank you to mighty ZM... :respect: :guitarplayer:
  15. ...and inside layout try 1 !
  16. Ok ....some more progress with case work....it's looking like something now.
  17. or to quote someone you should know quite well: "language is more than words"....
  18. HI guys,Finally got some progress on my new toy.Had some trouble getting some of the components, namely 1u MKC for C4.but boards are almost complete and so is the box, more photos later, right now here is one board...
  19. Thanks spavleski,Wouldn't want to make smoke with those nice SEMIs.Will post some pictures of my progress here soon.
  20. Hi ZM,I got my PCBs from "printed.cz" and am busy populating them.I do have a question, to start off...the zener diodes for output SEMI's protection do you advise their inclusion or not ?I'm not sure if i should put them in or not, although i did include them in the PCB redesign.
  21. Ok guys,I have read whole thread...and I have the feeling like before i built my Orions....i know i'm going to have something exceptional after i finish this...Thank you ZM for fantastic job . :drinks:I'm looking forward to this build....
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 137 Gosta (Pogledaj celu listu)
    450.7k
    Alen
    Alen
