crni.
Babovan
Sve objavljeno od crni.
  1. crni.
    Koji Linux
    uradio i evo šta se dešava
  2. crni.
    Koji Linux
    to je tačno...ali...
  3. crni.
    Koji Linux
    ne vredi miko, slab sam ja u ovome a opterećujemo ostale...snaći ću se već nekako hvala ti puno na trudu
  4. crni.
    Koji Linux
    rado bih ti dao kod za timvjuver ali neće da se instalira, kao i sve ostalo
  5. crni.
    Koji Linux
  6. crni.
    Koji Linux
    traži mi gde da ga sejvujem
  7. crni.
    Koji Linux
    piše, ali ne znam da prepravim na GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
  8. crni.
    Koji Linux
    nema, posle svakog updatea, upgradea ili instalacije uvek isto: Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: cdparanoia cube2 k3b-data kinit kio kpackagetool5 libdbusmenu-qt5-2 libenet7 libfam0 libk3b7 libkf5archive5 libkf5attica5 libkf5auth-data libkf5auth5 libkf5bookmarks-data libkf5bookmarks5 libkf5cddb-data libkf5cddb5 libkf5codecs-data libkf5codecs5 libkf5completion-data libkf5completion5 libkf5config-data libkf5configcore5 libkf5configgui5 libkf5configwidgets-data libkf5configwidgets5 libkf5coreaddons-data libkf5coreaddons5 libkf5crash5 libkf5dbusaddons-data libkf5dbusaddons5 libkf5declarative-data libkf5declarative5 libkf5doctools5 libkf5filemetadata-data libkf5filemetadata3 libkf5globalaccel-data libkf5globalaccel5 libkf5guiaddons5 libkf5i18n-data libkf5i18n5 libkf5iconthemes-data libkf5iconthemes5 libkf5itemviews-data libkf5itemviews5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5 libkf5kiofilewidgets5 libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5notifications-data libkf5notifications5 libkf5notifyconfig-data libkf5notifyconfig5 libkf5package-data libkf5package5 libkf5quickaddons5 libkf5service-bin libkf5service-data libkf5service5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5 libkf5wallet-bin libkf5wallet-data libkf5wallet5 libkf5widgetsaddons-data libkf5widgetsaddons5 libkf5windowsystem-data libkf5windowsystem5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5 libkwalletbackend5-5 libmikmod3 libphonon4qt5-4 libpolkit-qt5-1-1 libqt5qml5 libqt5quick5 libqt5quickwidgets5 libqt5script5 libqt5texttospeech5 libsdl-mixer1.2 linux-headers-4.15.0-44 linux-headers-4.15.0-44-generic linux-headers-4.15.0-45 linux-headers-4.15.0-45-generic linux-headers-4.15.0-46 linux-headers-4.15.0-46-generic linux-headers-4.15.0-47 linux-headers-4.15.0-47-generic linux-headers-4.15.0-48 linux-headers-4.15.0-48-generic linux-image-4.15.0-44-generic linux-image-4.15.0-45-generic linux-image-4.15.0-46-generic linux-image-4.15.0-47-generic linux-image-4.15.0-48-generic linux-modules-4.15.0-44-generic linux-modules-4.15.0-45-generic linux-modules-4.15.0-46-generic linux-modules-4.15.0-47-generic linux-modules-4.15.0-48-generic linux-modules-extra-4.15.0-44-generic linux-modules-extra-4.15.0-45-generic linux-modules-extra-4.15.0-46-generic linux-modules-extra-4.15.0-47-generic linux-modules-extra-4.15.0-48-generic phonon4qt5 phonon4qt5-backend-vlc Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Setting up linux-image-4.15.0-51-generic (4.15.0-51.55) ... Processing triggers for linux-image-4.15.0-51-generic (4.15.0-51.55) ... /etc/kernel/postinst.d/dkms: ERROR (dkms apport): kernel package linux-headers-4.15.0-51-generic is not supported Error! Bad return status for module build on kernel: 4.15.0-51-generic (x86_64) Consult /var/lib/dkms/elantech-0608/0.2/build/make.log for more information. /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-4.15.0-51-generic /etc/kernel/postinst.d/zz-update-grub: Sourcing file `/etc/default/grub' /usr/sbin/grub-mkconfig: 1: /etc/default/grub: i8042.reset i8042.nomux i8042.nopnp i8042.noloop quiet splash: not found run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 127 dpkg: error processing package linux-image-4.15.0-51-generic (--configure): installed linux-image-4.15.0-51-generic package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: linux-image-4.15.0-51-generic E: Sub-process /usr/bin/dpkg returned an error code (1)
  9. crni.
    Koji Linux
    da, to sam ovde već pitao...touchpad mi ne radi od početka, ali mi sve drugo radilo...šta mu je sad?
  10. crni.
    Koji Linux
  11. crni.
    Koji Linux
    neće ovu verziju pa neće Setting up linux-image-4.15.0-51-generic (4.15.0-51.55) ... Setting up linux-modules-extra-4.15.0-51-generic (4.15.0-51.55) ... Processing triggers for linux-image-4.15.0-51-generic (4.15.0-51.55) ... /etc/kernel/postinst.d/dkms: ERROR (dkms apport): kernel package linux-headers-4.15.0-51-generic is not supported Error! Bad return status for module build on kernel: 4.15.0-51-generic (x86_64) Consult /var/lib/dkms/elantech-0608/0.2/build/make.log for more information. /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-4.15.0-51-generic /etc/kernel/postinst.d/zz-update-grub: Sourcing file `/etc/default/grub' /usr/sbin/grub-mkconfig: 1: /etc/default/grub: i8042.reset i8042.nomux i8042.nopnp i8042.noloop quiet splash: not found run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 127 dpkg: error processing package linux-image-4.15.0-51-generic (--configure): installed linux-image-4.15.0-51-generic package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: linux-image-4.15.0-51-generic E: Sub-process /usr/bin/dpkg returned an error code (1) poslednja verzija je 4.15.0-50 a ovu 51 neće da instalira
  12. crni.
    Koji Linux
    i šta sad da radim da izađem iz ovoga?
  13. crni.
    Koji Linux
    nisam očekivao ovakve probleme na linuxu
  14. crni.
    Koji Linux
    moj linux mint neće da mi apdejtuje softvere tj ne radi update manager i neće da instalira nove za update izlazi sledeće poruka E: linux-image-4.15.0-51-generic: installed linux-image-4.15.0-51-generic package post-installation script subprocess returned error exit status 1 a kad hoću da instaliram ovo izlazi na terminalu Processing triggers for linux-image-4.15.0-51-generic (4.15.0-51.55) ... /etc/kernel/postinst.d/dkms: ERROR (dkms apport): kernel package linux-headers-4.15.0-51-generic is not supported Error! Bad return status for module build on kernel: 4.15.0-51-generic (x86_64) Consult /var/lib/dkms/elantech-0608/0.2/build/make.log for more information. /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-4.15.0-51-generic /etc/kernel/postinst.d/zz-update-grub: Sourcing file `/etc/default/grub' /usr/sbin/grub-mkconfig: 1: /etc/default/grub: i8042.reset i8042.nomux i8042.nopnp i8042.noloop quiet splash: not found run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 127 dpkg: error processing package linux-image-4.15.0-51-generic (--configure): installed linux-image-4.15.0-51-generic package post-installation script subprocess returned error exit status 1 Processing triggers for libc-bin (2.27-3ubuntu1) ... Errors were encountered while processing: linux-image-4.15.0-51-generic E: Sub-process /usr/bin/dpkg returned an error code (1)
  15. zarđala, nego šta, ceo dan na plaži...padne kiša, oni stave mušemu preko i teraj ok, navikao sam ja na zvuk takvih kutija kad puštaju rave, disco i tako to, ali ovi momci su puštali po ceo dan fenomenalnu muziku...francuski džez, akustični bluz, fado, bosu...i to se tako čuje da sam bio ozbiljno uzdrman
  16. mozak mi jednostavno odbija da takvu stvar stavim u sobu, a opet, zvuči u pm
  17. ebga, već jednom rekoh, razglasni zvuk mi jedino ima smisla...sve ostalo tunjavo
  18. mene ovo oduševilo kako zvuči, a pojma nemam šta je
  19. crni.
    KODI TV
    ja u favorite ubacio kanale sa sbb-a koji me zanimaju i doviđenja prijatno televizija bi imala smisla kad bi radila baš tako, da biraš šta ćeš da gledaš...dobiješ, recimo, privju na dan-dva a posle plaćanje...jedan kanal 100 dinara, pa da vidimo onda ko je dobar a ko nije i šta se gleda a šta ne
  20. crni.
    KODI TV
    a to...ok možda je moglo desni klik, info, pa se pokupi programska šema sa sajta određene tv...automatsko ažuriranje i eto...
  21. crni.
    KODI TV
    miko, jel može na kodiju da se vidi tv program određenih kanala? dnevni ili nedeljni, neka programska šema?
  22. crni.
    KODI TV
    čovek je posvećen onome šta voli i bogumi zna znanje nego miko, daj još nešto podeli sirotinji raji
  23. crni.
    KODI TV
    instalirao, podesio, radi... hvala miko...bez tvog uputstva ne bih uspeo konačno imam sport klub
  24. crni.
    KODI TV
    sad videh da radi, ali instalacija komplikovana u pm
  25. crni.
    KODI TV
    a jel to radi na linuxu?
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 19 Gosta (Pogledaj celu listu)
    452.7k
