sp300b Napisano Jun 13, 2009 Share #23 Napisano Jun 13, 2009 Pogledaj ovde - mozda nadjes nesto Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Jun 13, 2009 Autor Share #24 Napisano Jun 13, 2009 Ma sto rece onaj deda kad kupovao vijagru: " nije do mene, do babu je", Nije do WD nego do Viste. Sad ni DVD ne mogu da otvorim. Link to comment Podeli na ovim sajtovima More sharing options...
BlueSky Napisano Jun 13, 2009 Share #25 Napisano Jun 13, 2009 Pa jel ima u Event Viewer-u pod kategorijom System neki Error ili Warning koji je vezan za hardver ili softwersku gresku sa periferijama? Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Jun 13, 2009 Autor Share #26 Napisano Jun 13, 2009 The GeneLink Software Router Driver service failed to start due to the following error: A device attached to the system is not functioning.System - Provider [ Name] Service Control Manager [ Guid] {555908D1-A6D7-4695-8E1E-26931D2012F4} [ EventSourceName] Service Control Manager - EventID 7000 [ Qualifiers] 49152 Version 0 Level 2 Task 0 Opcode 0 Keywords 0x80000000000000 - TimeCreated [ SystemTime] 2009-06-13T10:20:48.000Z EventRecordID 19291 Correlation - Execution [ ProcessID] 0 [ ThreadID] 0 Channel System Computer Laptop Security - EventData param1 GeneLink Software Router Driver param2 %%31pa onda:The device, \Device\CdRom0, has a bad block. Link to comment Podeli na ovim sajtovima More sharing options...
BlueSky Napisano Jun 13, 2009 Share #27 Napisano Jun 13, 2009 Ufff pojma nemam sta se desava.... Mora dublje da se pogleda u komp....ja bi licno bootovao neki Live Linux sa fleske ili CD-a pa ako tamo radi onda bih tako iskljucio mogucnost hardverskog problema. E sad, da se ne bi mucio sa skidanjem iso fajlova sa neta i sl. moze Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Jun 13, 2009 Autor Share #28 Napisano Jun 13, 2009 Kako sad ni DVD RW drive ne radi ne znam sta da misim Ne mogu ni da ga butujem sa CDa Link to comment Podeli na ovim sajtovima More sharing options...
BlueSky Napisano Jun 13, 2009 Share #29 Napisano Jun 13, 2009 E pa ako nece ni da bootuje sa DVD/CD-a onda nije problem do Viste. Ili BIOS nije podesen kako treba ili je nesto crklo. Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Jun 13, 2009 Autor Share #30 Napisano Jun 13, 2009 Nisam probao BOOTovanje ali CD ne cita Link to comment Podeli na ovim sajtovima More sharing options...
krvimozak Napisano Jun 13, 2009 Share #31 Napisano Jun 13, 2009 Nisam probao BOOTovanje ali CD ne citaA sto ne pitas mog kuma u cemu je problem? Mozda te on opravi... Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Jun 14, 2009 Share #32 Napisano Jun 14, 2009 Mozda je mackica razvalila top score... Treba paziti ko ti cacka racunar kada nisi prisutan... Link to comment Podeli na ovim sajtovima More sharing options...
