964 -
9
Postovi objavljeno od крокодил
Na prodaju ovaj CD risiver u dobrom stanju.Kod mene je vise od 5 godina, čini mi se.
Ništa nije popravljano na njemu, osim promenjenog remena . Nad kao Nad, ni bolji ni lošiji od ostalih. Radio odličan, cd dobar. Jedini problem se nekad javi na displeju, pobrka komande, pa umesto da pređe na drugu pesmu on sa cd-a prebaci na radio. To se desava ponekad, ne uvek. Na jednom ćošku ima mala ogrebotina. Cenim ga 100 evra, ali bi ga rado menjao za bolju gramofonsku glavu. Otvoren sam i za druge predloge.
Nemam originalni daljinski, ali za dodatnu cifru mogu da dam Lodžitek daljinski. Slike mi nisu dobre, postaviću sutra.
Ovo su slike sa net-a. Članovima foruma dajem na probu uz plaćanje troškova slanja uređaja.
Model je izašao 1999 godina i tad koštao nemalih 899 kanadskih dolara - http://www.audio-ideas.com/backiss/almanac-2000/nad_l-40.html
Evo karakteristika - SPECIFICATIONS - NAD L-40
Amplifier Section
Continuous average power output into 8ohm,
stereo 20W (13dBW)
(THD 20Hz - 20kHz) 0.05%
Rated distortion (max. continuous power per channel) 25W
Clipping power IHF
dynamic headroom at 8ohm 3dB
IHF dynamic power (2/4/8ohm)80W/60W/40W
Damping factor (ref. 8ohm 50Hz)>100
(A weighted) ref. 1W93dB
Signal to noise ratio
ref. rated power106dB
± Frequency response 20Hz - 20kHz 0.5dB
Tuner Section
Usable sensitivity 1.5µV
50dB quieting Mono2.5µV
Stereo30.0µV
Capture ratio (45dBf)4.5dB
Selectivity, alternate channel78dB
CD Player Section
Disc capacity 120mm or 80mm
Digital-to-Analogue conversion Single Bit
± Frequency response 5Hz-20kHz 0.5dB
De-emphasis error <0.3dB
THD (at 0dB, 1kHz) 0.0025%
Dynamic range 98dB Linearity +0.5dB;0 to -90dB
Wow and Flutter Unmeasurable
Physical Specifications
(W x H x D) 17.1875" x 3.75" x 11.25" (435 x 95 x 285 mm)
Dimensions Net weight 16.1 lbs(7.3 kg)
CD player, Tuner and Amplifier all integrated in one chassis uitive and easy to operate i 20W x 2 Continuous power output (8 ohms) Amps of peak current capability i Separate power regulators for analog and digital sections i Easy to use, 10 button Remote Control Handset i FM tuner with 20 presets i NAD Link
Molim zakljucati. Otislo u Suboticu. Hvala.
Amplifier Section
stereo 20W (13dBW)
Clipping power IHF
Tuner Section
Stereo30.0µV
CD Player Section
CD player, Tuner and Amplifier all integrated in one chassis uitive and easy to operate i 20W x 2 Continuous power output (8 ohms) Amps of peak current capability i Separate power regulators for analog and digital sections i Easy to use, 10 button Remote Control Handset i FM tuner with 20 presets i NAD Link -
zafaljujući Leonardu koji je bio toliko ljubazan da mi napravi kopču
i to ne jednu koju sam ga zamolio da napravi već je napravio dvije
a koje su usput ispale feneomenalno da se maltene ne razlikuju od originalnih thorensovih
promjenih na jednom armwandu kopču koju je lokalni majstor radio a koja nije bila ok
kako je Leo poslao dvije kopče zadao mi je zadatak da napravim još jedan armwand
zato je poslužila rashodovana ručica od duala sa headshelom
ostalo je da se napravi konektor koji ide u kopču
za njega je iskorišćena jedna stara plastika iz rashodovane ručke
ostalo je samo da nađem dobru bakarnu punu žicu debljine 1,2mm i da sastavim i ovaj armwand
kako mi je falio tonearm finger lift malo sam liječio nerve i turpijao alu traku tako da sam naprvio nedostajući komad
najveći problem je bio otvoriti na širini aluminijuma od 3 mm rupu sa navojem od 1,8mm za kačenje šarafa glave ali mi je tu jedan čelični šraf poslužio kao nareznica i ispalo je da valja
sad ima savim dovoljno ručica (6 komada)
i nadam se da sam završio sa ovim
jedan armwand čeka Grado green glavu a drugi shure v97xe
Leo fala još jednom
Свака част !
Ово је најбољи и најсигурнији начин за пробу, тест главе. Ја на грамофону имам фиксни шел и кад треба да пробам другу главу одмах
се расплачем. Мука неописива, нисам једном лемио конекторе. Да попиздиш. А са годинама видим све лошије (гле чуда), тако да ћу морати
мењати грамофон. Баш ме интересује у директном мечу која ће глава победити...
Bolje izotvaravaj temu sa zvučnicima koje si pravio. Lako ćemo za vino i objekte. Za to je uvek lako
Зву, ово моје је много испод нивоа који сте поставили. Ствар је у томе што мени ради посао...
Звучници су Фостекс 166 фул рејнџ, у фабрички препорученим бек лоудид хорнама и везан стари Пиониров ПТ 204 булит твитер преко електролита. Како ни дан данас нисам урадио финиш (гологуз медијапан), није ми проблем да их довучем ако мислите да има смисла.
Ја имам домаћих урадака, али нисам ништа ја направио осим кутија и чисто естетских побољшања на тим справама.
А за пиће питам јер сам мислио да спонзоришем вино, 10-15 л, или ватрену воду (прва лига, није оно што се прави за продају), него не знам хоће ли бити могуће и послужити га тамо ( ако је фешта у неком локалу угоститељског типа - онда неће моћи).
Шта се пије на овој манифестацији ?
Не знам где да денем ово, али ваљда може и овде... У доколици, а као облик терапије на веселу стварност, узео сам да средим стари радио апарат, Минерва 414 из , ваљда, 1940-е године. У поприлично добром је стању, али прво радим кутију.
Нисам сигуран, али мислим да је шелак на фурниру. Лако се скида и скоро све сам ишмирглао и исгитовао.
Не знам шта сад да ставим ? Мало ћу га тонирати, а онда најобичнији лак или шта већ?
Друга ствар, бакелитна решетка, тј оквир, нигде није сломљена, али има онај мат, старински, који не знам како да скинем ? Зна ли неко чим се то третира, маже или шта већ '? Ово је тај модел, али је слика са нета.
Свако добро.....
Хвала Вам Импулсе, некако сам Келко сметнуо са ума. Поручено.
Култни грамофон г-дина Вердиеа сам видео у "Стерео"-у осамдесет и осме, чини ми се. Шокирао ме приступ и изглед, али га никад нисам ни видео ни чуо. Као ни његове цевне појачиваче. Овај преамп ми се допао одмах на први поглед, минимализам, мала кутија (гвожђе, 3кг), пасивни преамп, али са могућности активног рада. Уз пре је стигао и исправљач, за активни режим. Пробао сам га на активним Грундиг кутијама (оне су прошли викенд одпутовале у Немачку) - одлично, а са укљученом струјом страхота. Искрено говорећи, ја нисам ни знао да Грундиг може тако ЈАКО и жестоко да праши.
Један потенциометар је прекидао, и ја контактирам Г-дина Вердијеа да ми каже које да купим потове, да их заменим оригиналима. Иначе, преамп је 93-е коштао 1300 марона, а то им је био и најјефтинији производ који су направили . Ево одговора (обожавам овог човека) :
Dear Mr Manojlovic,
Those potentiometers have nothing special.
The same can be found everywhere in all electronic shops.
Nevertheless, if you don't find them - that seems impossible - I will send them to you.
Best regards.
J.C.VERDIER
Онда ја отворим кутију и ... ни трага од неких егзотичних решења или елемената.
Ево слика са горње и доње стране. Сликао сам у великој резолуцији, али сад само смањујем. Најлуђе је то , што ово СТВАРНО ради посао. СаХ ће ми средити оне несретне СЕТ-ове, па ћемо онда видети. Преамп је и купљен за њих.
Невероватно је да сам ја ово сликао, окачио слике и нисам приметио да нема оп ампа ! Ево га, само подножје на слици ... Има ли неко идеју који оп амп да пробам? Немам схему, али покушаћу да нађем..
Немам везе са овим, баш никакве, али ме некако срамота...
Aahhhh. Kolega Sax ce me sa'raniti sa svojim fotografijama ! A znam pouzano da ima dobar fotoaparat........
Једва се улоговах, и то на старом рачунару. Изгледа да сам свуда "запамтио" лозинке, па у покушају да их променим користио старе, и гле чуда - неће.
Већ неко време ми фали високих на звучницима (Фостех 166 у БЛХ), али како сам променио простор, па каблове и извор, мислио сам да је због тога. А и остарило се у међувремену...
Елем, много ми да дам новце за Фостех T90A (
[*]8 ohm impedance
[*]Frequency response from 5kHz to 35kHz
[*]106dB sensitivity at 1w/1m (3.3ft)
[*]TOP MOUNT - wood stand included as pictured
[*]Flange 60 mm
[*]Depth 74.1/ 87.8 mm
[*]Znom 8 ohm
[*]fs 5000 Hz
[*]Sensitivity 1W / 1m 106 dB
[*]Nom. Power 50 W
[*]Net weight 800 g) , па нешто мислим, има ли смисла уместо њега убацити овај булит твитер -
[*]8 ohm impedance
[*]Flange 60 mm
[*]Znom 8 ohm
[*]fs 5000 Hz
[*]Nom. Power 50 W
Bela boja je tonirani želkot, dakle nije farbanje u pitanju nego tonirani osnovni sloj.
Ne znam kako da pojasnim. Ko se od članova foruma odluči da pravi zvučnike, dobiće horne tek kada otvori svoju temu u kojoj se vidi da je izradu zvučnika započeo - dakle nacrti, napravljen kabinet, kupljeni midbasovi i B&C DE250 kompresioni drajveri i ostale sitnice.
Cilj cele ove priče je da se pomogne samograditeljima koji do ovakvih horni ili ne mogu da dođu ili je jako skupo. Nije cilj masovna proizvodnja i barem je što se mene tiče neće biti.
Za jedan par je potrebno oko 4 dana da se naprave sa svim slojevima, sušenjem i završnom obradom - dakle tempo će zavisiti od mog slobodnog vremena.
Поштено .
ааааааахххх какава дивота ! И презентација. Тек сам сад видео ово, следећи линк са оног форума.
Браво !
Сачекаћу да оду на 1000 евра, па онда купујем. Верујем да ћу наговорити власника да ми да попуст од 100 евра (10%), а то је дупло више од 50 понуђених евра, зар не ?
Koreanci, sunce li vam vaše...
е, нека им је рекао..
Lepo, lepo... Meni bi, da sam ga ja kupio, smetala samo pomalo prenaglašena struktura furnira. Volim kada je toliko glatko da kada se navuče ženska čarapa preko ruke i prevuče preko površine, nigde ne zapne. Međutim, nije bitno kako bih ja voleo, bitno je da kolega uživa u svojoj novoj "igrački" ... U zdravlju ga trošio Ninja!
Кажу да се некад тако проверавао квалитет тек постављеног и лакираног паркета . Мајстор заврши и онда, пре исплате, газдина жена скине ципеле и отклиже по паркету - ако су чарапе остале читаве, посао је добро обављен.
Ово је испало из употребе, вероватно би с обзиром на квалитет у данашње време било крви до колена...
Montirana je tangencijalna ručka ET sa LYRA glavom. Trebalo je biti veoma pažljiv i precizan
kod odredjivanja tačke montaže. Jednom montirana ručka se iznenadjujuće jednostavno podešava.
Kritična je paralelnost nosača ručkice i površine ploče!
Visina igle se može podesiti u toku reprodukcije i osluškivati efeket. Toliko visoko se može
podići da je moguće skinuti ili postaviti mat-tanjir od 25mm, a da ne pričamo o debljini ploče!!!!
...O zvuku i sistemu u sledećem broju!
Вауууууууууу.! Прави врхунски рад, свака част момци !
Мени би било веома интересантно да напишеш колико је која операција коштала, као и материјали за плинт ? Ако није по правилима , може и на пп. И опет, Браво !
Свако добро
Тридесет и кусур лампи Х 1 тисућа = тридесет и кусур хиљада еврића. Јел сад јасније ? http://www.orpheusaudio.gr/node/1878Ovaj Verdier pećeruje, u mm/mc pream uvalio trideset i kusur lampihttp://www.jcverdier.../ADSL/MMMC.htmlšto se troši kad može sa jednom ili dvije
Кад се сад нисам шлогиро !Хвала за ову информацију, никад ми не би пало на памет.lepo ti je eric napisao, to je najobicniji najbazicniji pasivni regulator glasnoce - potenciometar u velikoj kutiji, cini mi se baferom koji moze a ne mora da se koristi.nego, kada si vec ponosni vlasnik verdierove sprave, ne znam da li znas da je jedna solidna sprava ove manufakture projektovana i napravljena u beogradu. u pitanju jedan od prvih, mozda cak i prvi pojacivac koji je izasao pod markom JC verdier, uradio ga je nebojsa maricic (koji je zajedno sa miletom dabicem i americkim partnerom danas jedna trecina teresonica). mislim da je uradjen sa 6L6 ali me ne drzi za rec, isto tako mislim da je to ovohttp://www.jcverdier...L/Ampli220.htmlvideo sam ga uzivo kod nebojse, stoji mu u racku ali ga ne slusa - ima bolje sprave u sistemu.
Ако неког интересује (веома мало има на нет-у), ево фирминог представљања овог преампа -http://www.jcverdier.com/ADSL/Pre_ctrl.html
Trenutno na sajtu 3 članova, 2 Skrivenih, 15 Gosta (Pogledaj celu listu)
Ukupan broj tema435k
Kupuj dok nije otišlo...
in Data and tips
И тата би сине .. Без шале, стварно добро изгледају. Ваљда су 12-ице, нема резона за мање. Битно је задњих 15-20 минута, видећемо колико вреде.... А вреде тачно онолико колико их неко плати.
