zika
Sve objavljeno od zika
  1. zika
    P: Polica (daske 5 kom)
    Je l' ove: http://www.diyaudio.rs/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=9577...?
  2. http://www.diyaudio.rs/topic/2891-pojasnjenje-wav-audio-redbook-cd-ili-ne/page__view__findpost__p__58711 : Please...
  3. zika
    Passive-ac ili Active-ac...?Lako je Tebi kada stavljaš na orman. Kod mene su ta mesta, odavno, već, zauzeta...
  4. zika
    Kaži, lepo, da Ti prija Laguna...
  5. zika
    Šta je, sada, sa tim preamp-om...?
  6. Da razgraničimo dve „struje“ koje vidim ovde:-i- šta .wav jeste, ili nije, i slično...-ii- šta je neko rekao ili nije o tome šta .wav jeste, ili nije, i slično...-i- jeste i može biti tema razgovora ovde, prema našim znanjima, volji za objašnjavanjem i prilikama...-ii- nije i ne bi trebalo da bude tema ovde...Od mene, toliko...
  7. To mi reci Ti, brate rođeni...Ja sam, k'o i obično, ozbiljan...
  8. “Redbook audio is just a general term for raw, uncompressed audio. WAV and AIFF are both redbook formats. They both produce the exact same sound the same way. A WAV file and AIFF file of the same audio will actually be very similar. If I recall correctly (it's been a long time since a working in low-level audio), the only difference is the header and footer of the file... and maybe an endian issue.“ „There is absolutely nothing special about the audio data encoded on a CD. The only difference between a "raw" 44.1KHz 16-bit stereo WAV file and CD audio is the byte ordering. It isn't necessary to convert a WAV or AIFF file to a special format to write to a CD, unless you're using a format that your recording software doesn't recognize. For example, some software won't record from MP3 files, or from WAV files that aren't at the correct sampling rate. Similarly, you don't have to do anything special to audio extracted from a CD. It's already in a format that just about anything can understand. Just put your audio into the correct format -- uncompressed 44.1KHz, 16-bit, stereo, PCM -- and the software you use to write CDs will do the rest. All of the fancy error correction and track indexing stuff happens at a lower level. Don't get confused by programs (such as Win95 Explorer) that show ".CDA" files. This is just a convenient way to display the audio tracks, not a file format unto itself. See section (2-36).“ Mrzelo me je da pišem, ukradoh dva, relative-no representative-na odgovora...
  9. zika
    Šta li se desilo sa onim kućištem na vrhu... ? :to_become_senile:A i ona siva kutija u sredini mi je poznata... Ne znam, samo, onaj preamp...
  10. http://www.kupujemprodajem.com/Kenjalo-mono-blokovi-395854-oglas.htm?filter_id=1241741
  11. Moraću, što pre, da čujem taJ2... Ali, stvarno...Kako se odnosi prema F5DnD?Ili, da, „prepravim“ F{3,5} u J2...
  12. Hvala! I na slici i na podsticanju na putovanje...
  13. Što je lepo videti Vas i ovde... Dobrodošli. Je l' može jedna legend, ko je ko na slici...? Naravno, neke prepoznajem... Recimo Khadgar2007-a ... Hteo sam doći i ove godine, ali... Ko zna, veoma primamljivo. I mesto gde se održava i društvo i razlog... Bojim se, samo, da biste morali da mi pretresete auto pre polaska nazad... Videćemo. Sve je moguće.
  14. A,ne, kokice su za mene. Iako ne smem da ih jedem, so, pritisak... No, poslužite se, slobodno...
  15. zika
    Vodokotlićarenje
    Trudim se da u toj prostoriji provedem što je moguće manje vremena... Ergo, tišina, koliko je to moguće, mi prija...Za zvučnu kulisu, u vanrednim prilikama, tako i u gostima, koristim šum vode iz česme...
  16. zika
    KABLOVI
    Nema potrebe...Nema važno, nije veze...
  17. http://www.diyaudio.rs/topic/2833-video-pojacavaci/page__view__findpost__p__57256
  18. zika
    DIY gramofon II
    Ako Ti urade pre, obećanog Ti, vremena, ne valja. Da su Ti, u subotu, rekli da dođeš u ponedeljak, opet, Ti, ne bi valjalo. Jesi namćor. Taman htedoh da uživam kako si vredan i kako Ti je krenulo, kad se House probudi u Tebi...Gori si od mene...
  19. zika
    KABLOVI
    http://www.hi-files.com/forum/index.php?/topic/14507-vasa-pozitivna-i-negativna-iskustva-sa-pre-prodavcima-hifi/page__view__findpost__p__312473
  20. zika
    Vodokotlićarenje
    Da, videh, malo pre, da ima i na site, al' mi je, nekako, bliže Batajnica nego Bgd, ne prelazi se most...Hvala na hint-ovima za mrežice, pokušaću da nađem i da odradim savetovano. Kad dođe do toga, obavezno, sledi izveštaj...Hvala!
  21. zika
    Vodokotlićarenje
    Tačno ste napisalo ono što mi se mota po glavi ceo dan, al' se ne odlučujem da pametujem dalje...1. Ko god mi nađe u Beogradu ili bilo gde one mrežice sa zaptivnom gumom za crevo vodoktlića i za slavinu za mašine za {veš, suđe}, poljubiću ga nasred Terazija i plaćam trostruko... Treba mi 4 te manje i 4 te veće, ili 8+8, za svaki slučaj, da se nađe...2. Upravo gledajući sliku Geberit-ovog kotlića, ostajem pri savetu da se zamene dva dela koja sam naveo u svojoj poruci (vidi gore) i to je to... Kordal ne poznajem al' se zahvaljujem na usmerenju... Uh, cool to je u Batajnici, pa to je great...!
  22. zika
    Aktivno ludilo...
    Da znaš da mi je, i dalje, em milo, em drago, za Tebe... Da Ti sve ide tako k'o ovo danaske...
  23. http://www.diyaudio.rs/topic/2833-video-pojacavaci/page__view__findpost__p__57256
  24. zika
    DIY HDD pakovanje
    To sokocalo korisim za PC. Nekako mi se čini da je davila muziku. No, nemam jasan stav oko toga... Mrzi me da probam danima da bih stekao, možda, utisak...Za PC je OK. Spasilo me je stalnih zamrzavanja jer napajanje nije umelo da se izbor sa mikrokratkim prekidima napona...Uh, kad čujem da cakće, samo se naježim...
  • Trenutno na sajtu   1 član, 0 Skrivenih, 135 Gosta (Pogledaj celu listu)
    452.1k
    Sanjalica
    Sanjalica
