Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. pederlazov!
  2. I'm more interested in your own words and opinion , than in Srayan's
  3. ja samo reko' da potpisujem sto si ti reko
  4. @ Stein ja tebe ne pratim ....
  5. ti odgovara taj ruski amp za kuciste ?ima se jedan , a zaboravio te ranije pitati
  6. sta si ti hteo sa tom postom ?odgovaras ..... ili pitas ?
  7. you had some doubts ?
  8. considering that - little Sonidos may be complete solution for your room , without any need for augmentation from low sideyou'll be surprised both with amount of SPL and physical volume of sound "body" , coming from them leave R1 & R3 at 10Ksay that gain of ~ 3,9 to 4,7 (11,8db to 13,4db ) will suffice in that case - alter both R5 and R6 to 39K ( max 47K)check offset after change
  9. ma ja samo dizem prasinu sad , pre nego ga dam u oglase za par nedelja .......
  10. btw.go back later , after 10 albums , and tell us more about sound
  11. off course !!having preamp with full blast gain for follower stage - connected to 1V5 declared input of amp is almost certain disaster ...... as leaking gas from stove when we'll see some pics of speakers ? edit: I see that you were faster with pics than me on keyboard
  12. slucajnost ;nece se ponoviti , obecavam
  13. kao prvo - da ti ja jos jednom - javno - iscestitam , i da te pitam sta si cekao do sad da devojku najzad ucinis postenom ? koja crvena kutija ?ima prepucijuma jos , ne boj se .......
  14. e - jednom i ti mene da pohvalis ....... :Viannen_loungelizard:usput- ista tema i na Big DiyA .mozda postoji neka razlika u textu (mozak mi na rezervi vec nekolicinu sati ) :http://www.diyaudio.com/forums/pass-labs/174674-papas-koan-papas-surprise.html#post2320759
  15. iskreno - samo sam amp pustio danas u rad - sto ce reci - preliminarno podesio mirnu struju i offset ; sutra-prekosutra sledi kuvanje i finalno podesavanje parametara , kao i slusni test ; ma sta test - slusanje davno bese kad sam imao Ikebana F4 na stolu ..... i mislim da je svirao jedno 3 dana ....... tako da i nece biti nekih iznenadjenja ; ono sto je najznacajnije ( po pitanju ampa nema neke frke , jer se covek na dobro lako navikne ) - meni srce puno eto - nisu jebeni novci sve u zivotu
  16. nalepnica "Papa's Surprise" vidljiva na slikama u temi linkovanoj u prvom postu , je strateski stavljena preko ostecenja na frontu - nastalom u transportu ;nije bila greda , iako se Vlada nasekirao , jer sam ja ionako skontao plan daisti front posaljem kod Lea na graviranje natpisa ;ispade da je Leonardo - posle dogovora - morao da ukloni postojeci elox , izbrusi front ponovo ,doradi 1+3 malih ivica, posalje na elox , te potom gravira logo koji sam smislio.danas mi stize post express posiljka .bese nekih trzavica u PP i e-mail komunikaciji sa Munze Glodačem važnih delova ........ nikako da mi napise koji nacin placanja preferira ...... no - kad sam otpakovao komadesku aluminijuma - posle prvih nekoliko minuta divljenja ( a ja sam od onih koji mogu da prevrcu - vec visegodisnje posedovani - Zippo - 10 min. po rukama , kao da ga vidim prvi put - diveci se "form follows function" ........ elem - posle prvih nekoliko minuta divljenja - skontah da ima i papiric zataknut u minuciozno spremljenu ambalazu ploce :(nadam se da Leo nece zameriti obznanjivanje rukopisa )
  17. http://en.wikipedia.org/wiki/K%C5%8Dan
  18. ostatak slika ;sto se tice detalja - ne znam da li sam sta propustio .....
  19. elem - beše opisano u temi http://www.diyaudio....dpost__p__45221 ono sto je Vlada (AR2) doneo kao poklon od Papa Nelsona . slede slike nastavka ; dual mono napajanje ( zajednicki primar trafoa za oba kanala , posebni sekundari i cap bank za svaki kanal ) sto ce reci - 2x18Vac - 2x Graetz - 2x( 33mF-0R1-33mF) ....... sve to po kanalu trafo 800VA kondovi na kanalnim pcb Elna 470uF/35V/125C ; 2 kom PSU filter bypass-irani sa 100nF neki poly , 2 kom kroz koje tece signal bypass-irani sa 10nF MKC ( polycarbonat) pcbs su predprodukcijske prototipne , pa sam ih ja prepravljao na finalnu iteraciju seme F4 , gde su izmene unesene zarad zastite ulaznih Jfeta od preteranog swinga ..... naravno - secamo se da je F4 voltage follower ....... power ozicenje Nauk ( precnik ~2,5mm stari - sa vrazje puno licni) , signalno 0,1mm posrebreni bakar trafo u sendvicu od sundjeraste gume 15R NTC kao soft start 15R NTC za spoj mase svakog kanala i case , koji je na uzemljenju . zemlja preko ferit prigusnice ferit prsten na oklopljenom mreznom vodu do toroida obilato koriscena platnena izolirka - mlogo fancy deluje
  20. elem , dok ne utarupam i ovde : http://www.diyaudio.com/forums/pass-labs/174674-papas-koan-papas-surprise.html
  21. znas ti , vagabondu belosveCki :rofl:bice i ovde kasnije - samo da se ispece kazance i da se odradi jos par obaveza - sa Vladom I batabanetom
  22. good luck !repetitio est mater studiorum:cheers:
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 97 Gosta (Pogledaj celu listu)
    454k
    DusanJovanovic
    DusanJovanovic
