565 -
Postovi objavljeno od Magura
Yes, barrel. As in 25 kg barrel. Can't buy less than that, as this is not a hobby product.Hence the offer. Magura
I had a friend visiting me today.His first comment when he entered the living room was : Oh they're big!Now my first thought was : quit ogling her titsAfter some thought, I realized he meant the Donuts.Funny thing is, just like with tits, that when you see them every day, after some time they don't seem all that big.........it's just that all the other amps/tits seems soooo small Magura
The varnish is the one Synflex offers for motor winding. I don't have it here, but can get to the barrel tomorrow. It is polyurethane based, heat curing.The same as I use for inductors.Magura
Ja nogen skal jo gøre det MaguraTako Zvu, ohrabri ga i ti malo...
Ok, let me try to mess with your Serbian slang....If you take the foil and twist the end into the shape of a round wire, it is possible to solder it using the solder mentioned above. If you play it smart, you nick the braided wire from a dead Dynaudio unit, as it is actually tinned aluminium. Thus you will be able to have respectable solder joints, both for the end where the foil is connected, and for the terminal end.Magura
I hope that circumstances and time permits that I come to the BAF this year. .....and that is a very good offer Vladimir. I'll take you up on it.Magura
The temp difference from the critter to the carbon heat spreader, is some 4 to 5C, a bit hard to get to measure.IRF244 critter runs at around 45C, sinks are maxing out at 30-32C, some 9C above ambient.Magura
Naah, just not that many options, when it comes to placing the system. Not that it makes any difference actually, but I too thought it would, so I measured the temp of the amp, once in place, and then moved away from the radiator....about 1C difference And now for something completely different: I have made a CLEAR photo. Mucho effort, but worked.Magura
Hi Andrics,No, not really. I'm drowning in work (supposedly to be considered a good thing), so the driver is on stand-by for the nearest future. Magura
It works very well, and the magic smoke stays inside the 3 legged critters MaguraIs it works or white smoke is released?
Yeah I had that feeling as well....spill the beans fluffy Serb Magura
Hmm, it seems that knitting has gotten her attention for now. I guess it will take about "one sweaters time", till she picks up the soldering iron again.Magura
Thermal characteristics are about the same as of copper. Look up graphite, and you got it. The big deal is that it has higher thermal transfer capacity in the direction of the fibers, so you can make two components track quite well thermally. I can't remember the temp differences of the case to carbon heat spreader, but I'll measure that this evening. Why such interest all of a sudden? Magura
What do you want to know? I mean more specific?Magura / Whom declared the Donut project "finished" last Sunday.
Ohh, this almost sounds too good to be true.Thanks Oliver.MaguraImam ja. 3,2MB PDF , rarovano 2MB. Kako da turim na forum?
It sure smells like one of those Beringer thingies that I'm not allowed to have Magurasorry Metaldanske - I didn't realized that drek is bidirectional ; Sir got it already .ask for two evals .....
Sure I'm nutz, that's been confirmed frequently Demo board = fun toy. Simple really Maguraya nutz ? why you need demo board of something which needs to be integrated on your mobo ?we'll be interested in continuing of that story - receiving side .
That looks real interesting.....and they got a demo board.Now how to convince them to send me a demo board? Magura
Hmm, seems like me culpa. The square is not 20Hz, but 25Hz, which makes a lot more sense. According to the calcs I've made, it sure does not do 20Hz in a reasonable way.20Hz sine is no problem though.MaguraFirst 20Hz square into 8R. This is actually better than I expected it to be. I aimed for things going south below 30Hz, and even at 20Hz it's actually fair enough.Magura
Thanks Vladimir,There are some nice, very clear, close-up's on the Gitzo page. Could be easier to just make one, as they're rather simple. Maybe an improved tripod Gitzo....Magura
That could very well be the end of that story. Making one is sure less hassle than shopping for one Magura
Yeah, I ought to get myself a small tripod. Any recommendations what to buy? Magura
Trenutno na sajtu 0 članova, 2 Skrivenih, 10 Gosta (Pogledaj celu listu)
Ukupan broj tema435.4k
REPARACIJA DRIVER-A
in Zvučnici
So, we now have a coil that is 8.5mm wide, and one that's 10.5mm wide.That ought to do the trick. Nasty weather, so no going to the remote storage to check up on varnish today.Magura
