  • unosa
    87
  • komentara
    338
  • pregledâ
    126223
Babelfish J2 , ongoing ...... no more; burned in !
bias & offset procedure done
clipping test done
installed switches for tying L & R inputs , for bi-amp duty .
they're made with common supply for both channels in case , because of possibility of use in parallel mode
in any case , when made as dual mono , wiring can be cleaner and nicer .
whatever , I'm satisfied .
bottom taster buttons will be replaced later ( pair of "START" buttons per amp just doesn't make much sense :sarcastic_hand: ) , and missing Cardas posts on one will be mounted as soon they arrive .
cheap & dirty amps for everyday's use , if you don't mind burnin' 2 x 200 W of electricity :rofl:
free tip for any user of A class amp - having Babysitter is cunning ......... as shown here : http://tinyurl.com/85ymtnm
6 Comments
gaggia
aaaaaaaa...cudoviste radi kao skalpel..kod mene je sada...ne znam sta me snaslo..
gaggia
`ocu da kazem da mi nije jasno odakle ovoliko detalja ..
ManicP
Ajd te rife i fancy kutije... ...al start dugme ko na formuli! Mlogo svidžam :wild:
hifish
Slike su da ti voda pocne curiti na usta!
A moze i pamecu da se pomeri... Ako mnogo gledas! :D
