ebe Napisano Jul 10, 2018 Share #1 Napisano Jul 10, 2018 Ne odgovara mi ova varijanta sa bluetooth-om pa prodajem kako bih kupio varijantu bez. Ide po nabavnoj ceni od 1600 din. Quote Using CSR8635 Bluetooth chip,Bluetooth V4.0,high software compatibility. Product Parameters: Model:XH-M548 Chip Type:TPA3116D2 Bluetooth module:btm835/csr8635(4.0) Transmission distance:Max 10m Voltage:DC12-24V Current:>3A Output Power:120Wx2 Efficiency ratio:>90% Sound track:Dual track Size:98*79*16mm Bluetooth module Parameters: Specification:Bluetooth V4.0 Modulation Mode:GFSK π/4 DQPSK,8DPSK Voltage:3.3-4.2V Suppotr Bluetooth Protocol:HFP V1.6,HSP V1.2,A2DP V1.2,AVRCP V1.4,DI V1.3 Work Current:≤30mA Standby Current:<50uA Temperature range:-40℃ to +80℃ Wireledd Transmission Distance:10m Transmit Power:Support CLASS1/CLASS2/CLASS3 8dBm Max Sensitivity:-80dBm<0.1%BER Frequency Range:2.4GHz-2.480GHz External Interface:PIO,SPI,Audio in/out and PCM,USB Audio Support:AAC,MPA,SBC,Stereo Distortion Factor:≤0.1% Module Size:21.9*14.1*1.8mm Link to comment Podeli na ovim sajtovima More sharing options...
zocky Napisano Jul 13, 2018 Share #2 Napisano Jul 13, 2018 Ako nije otišlo, da li može rezervacija do ponedeljka? Link to comment Podeli na ovim sajtovima More sharing options...
ebe Napisano Jul 14, 2018 Autor Share #3 Napisano Jul 14, 2018 Moze. Rezervisano do ponedeljka. Link to comment Podeli na ovim sajtovima More sharing options...
ebe Napisano Jul 16, 2018 Autor Share #4 Napisano Jul 16, 2018 Prodato. Link to comment Podeli na ovim sajtovima More sharing options...
