ManicP Napisano Oktobar 27, 2013 Share #1 Napisano Oktobar 27, 2013 Prodajem pojačalo Cambridge Audio Azur 640A V2.0 sa orginalnim daljnskim.Power output 75 watts (into 8?)120 watts (into 4?)THD (unweighted)<0.002% @ 1kHz, of rated power<0.050% 20Hz - 20kHz, of rated power<0.020% 20Hz - 20kHz @ 10wFrequency response (-1dB) 5Hz - 50kHzS/N ratio (ref 1w) >90dBInput impedances 47kohmsPower Amp damping factor >100Max power consumption 700wMin/On power consumption <35w (no signal)Standby power consumption <10wBass/Treble controls Shelving, ultimate boost/cut + /-7.5dB @ 20Hz and 20kHzDimensions 100 x 430 x 310mmWeight 7.4kg (16.3Lbs)Pojačalo u kozmetički odličnom stanju. Radilo u nepušačkom stanu bez boravka na žurkama. Pojačalo dolazi sa metalnim daljinskim upravljačem i kompletnim pakovanjem (kutija, stiropori, kesa, uputstvo, orginalni napojni kabl).Cena 250e. predrag.manic(at)gmail(dot)com Pojačalo se nalazi u Beogradu Link to comment Podeli na ovim sajtovima More sharing options...
ManicP Napisano Decembar 4, 2013 Autor Share #2 Napisano Decembar 4, 2013 Može lokot. Link to comment Podeli na ovim sajtovima More sharing options...
