Telefunken TS-860
sule
  • Odgovora 7
Popularni dani
Ne mož' bolji napravit' za te pare...
Specifications
Drive system: direct drive
Motor: 18V DC
Speeds: 33 and 45rpm
Pitch control: +-5%
Platter: 1kg, 310mm aluminium diecast
Tonearm: J-shaped static balance
Effective length: 237mm
Overhang: 16mm
Offset angle: 21.5 degrees
Signal to noise ratio: 65dB
Wow and flutter: 0.06%
Dimensions: 460 x 350 x 140mm
Manuali na vinylengine http://www.vinylengine.com/library/telefunken/ts-860-hifi.shtml (downloadable samo uz registraciju)
http://www.vinylengine.com/ve_downloads/index.php?telefunken/telefunken_ts_860_hifi_service_en_de_fr.pdf
http://www.vinylengine.com/ve_downloads/index.php?telefunken/telefunken_ts_860_hifi_sup_ic204_en_de_fr.pdf
