крокодил Napisano Jun 2, 2013 Share #1 Napisano Jun 2, 2013 Na prodaju ovaj CD risiver u dobrom stanju.Kod mene je vise od 5 godina, čini mi se. Ništa nije popravljano na njemu, osim promenjenog remena . Nad kao Nad, ni bolji ni lošiji od ostalih. Radio odličan, cd dobar. Jedini problem se nekad javi na displeju, pobrka komande, pa umesto da pređe na drugu pesmu on sa cd-a prebaci na radio. To se desava ponekad, ne uvek. Na jednom ćošku ima mala ogrebotina. Cenim ga 100 evra, ali bi ga rado menjao za bolju gramofonsku glavu. Otvoren sam i za druge predloge. Nemam originalni daljinski, ali za dodatnu cifru mogu da dam Lodžitek daljinski. Slike mi nisu dobre, postaviću sutra. Ovo su slike sa net-a. Članovima foruma dajem na probu uz plaćanje troškova slanja uređaja. Model je izašao 1999 godina i tad koštao nemalih 899 kanadskih dolara - http://www.audio-ideas.com/backiss/almanac-2000/nad_l-40.html Evo karakteristika - SPECIFICATIONS - NAD L-40 Amplifier SectionContinuous average power output into 8ohm, stereo 20W (13dBW)(THD 20Hz - 20kHz) 0.05% Rated distortion (max. continuous power per channel) 25W Clipping power IHF dynamic headroom at 8ohm 3dBIHF dynamic power (2/4/8ohm)80W/60W/40W Damping factor (ref. 8ohm 50Hz)>100 (A weighted) ref. 1W93dBSignal to noise ratio ref. rated power106dB± Frequency response 20Hz - 20kHz 0.5dBTuner Section Usable sensitivity 1.5µV50dB quieting Mono2.5µVStereo30.0µV Capture ratio (45dBf)4.5dBSelectivity, alternate channel78dBCD Player Section Disc capacity 120mm or 80mmDigital-to-Analogue conversion Single Bit± Frequency response 5Hz-20kHz 0.5dB De-emphasis error <0.3dBTHD (at 0dB, 1kHz) 0.0025%Dynamic range 98dB Linearity +0.5dB;0 to -90dBWow and Flutter Unmeasurable Physical Specifications(W x H x D) 17.1875" x 3.75" x 11.25" (435 x 95 x 285 mm) Dimensions Net weight 16.1 lbs(7.3 kg) CD player, Tuner and Amplifier all integrated in one chassis uitive and easy to operate i 20W x 2 Continuous power output (8 ohms) Amps of peak current capability i Separate power regulators for analog and digital sections i Easy to use, 10 button Remote Control Handset i FM tuner with 20 presets i NAD Link Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Jun 2, 2013 Share #2 Napisano Jun 2, 2013 Ja sam eto, spomenuo da imam zvučnicu viška, pa ako te zanima... http://www.diyaudio.rs/topic/5405-gramofonske-glave/page-12#entry152796 tamo je i nekoliko slika... Link to comment Podeli na ovim sajtovima More sharing options...
крокодил Napisano Jun 5, 2013 Autor Share #3 Napisano Jun 5, 2013 Na prodaju ovaj CD risiver u dobrom stanju.Kod mene je vise od 5 godina, čini mi se. Ništa nije popravljano na njemu, osim promenjenog remena . Nad kao Nad, ni bolji ni lošiji od ostalih. Radio odličan, cd dobar. Jedini problem se nekad javi na displeju, pobrka komande, pa umesto da pređe na drugu pesmu on sa cd-a prebaci na radio. To se desava ponekad, ne uvek. Na jednom ćošku ima mala ogrebotina. Cenim ga 100 evra, ali bi ga rado menjao za bolju gramofonsku glavu. Otvoren sam i za druge predloge. Nemam originalni daljinski, ali za dodatnu cifru mogu da dam Lodžitek daljinski. Slike mi nisu dobre, postaviću sutra. Ovo su slike sa net-a. Članovima foruma dajem na probu uz plaćanje troškova slanja uređaja. Model je izašao 1999 godina i tad koštao nemalih 899 kanadskih dolara - http://www.audio-ideas.com/backiss/almanac-2000/nad_l-40.html Evo karakteristika - SPECIFICATIONS - NAD L-40 Amplifier Section Continuous average power output into 8ohm, stereo 20W (13dBW) (THD 20Hz - 20kHz) 0.05% Rated distortion (max. continuous power per channel) 25W Clipping power IHF dynamic headroom at 8ohm 3dB IHF dynamic power (2/4/8ohm)80W/60W/40W Damping factor (ref. 8ohm 50Hz)>100 (A weighted) ref. 1W93dB Signal to noise ratio ref. rated power106dB ± Frequency response 20Hz - 20kHz 0.5dB Tuner Section Usable sensitivity 1.5µV 50dB quieting Mono2.5µV Stereo30.0µV Capture ratio (45dBf)4.5dB Selectivity, alternate channel78dB CD Player Section Disc capacity 120mm or 80mm Digital-to-Analogue conversion Single Bit ± Frequency response 5Hz-20kHz 0.5dB De-emphasis error <0.3dB THD (at 0dB, 1kHz) 0.0025% Dynamic range 98dB Linearity +0.5dB;0 to -90dB Wow and Flutter Unmeasurable Physical Specifications (W x H x D) 17.1875" x 3.75" x 11.25" (435 x 95 x 285 mm) Dimensions Net weight 16.1 lbs(7.3 kg) CD player, Tuner and Amplifier all integrated in one chassis uitive and easy to operate i 20W x 2 Continuous power output (8 ohms) Amps of peak current capability i Separate power regulators for analog and digital sections i Easy to use, 10 button Remote Control Handset i FM tuner with 20 presets i NAD Link Molim zakljucati. Otislo u Suboticu. Hvala. Link to comment Podeli na ovim sajtovima More sharing options...
