grau. Napisano Novembar 13, 2012 Share #1 Napisano Novembar 13, 2012 European Triode FestivalHeat up that soldering iron and get to work: this years topic is:THE SPUD AMPEvery participant is to build a stereo power amp(or two mono blocks) with a SINGLE activeamplification stage per channel.It is of no consequence whether that stage is single ended or push/pull in nature.- One stage in singled ended or Push Pull topology- Both tubes and solid state devices are permitted.- The use of CCS' ( Constant Current Source) or voltage regulation is permitted. So we don't consider this to ruin the one amplified stage concept. Integrated Circuits are not allowed, if they violate the one stage topology. (No Gainclones for example)- The use of input and/or output transformers is permitted- The preamp driving the amps will have an output impedance of approx. 600 Ohms, so the input impedance of the Spud should be high (10k or more)- Input level will be 2V eff max for full output- Overall gain is not fixed- The amps shall be capable of driving an 8-16ohm load Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Novembar 13, 2012 Share #2 Napisano Novembar 13, 2012 i?oćeš učestvuješ? Link to comment Podeli na ovim sajtovima More sharing options...
grau. Napisano Novembar 13, 2012 Autor Share #3 Napisano Novembar 13, 2012 hahane, samo prenosim koga bi moglo da zanima. to je ozbiljan skup. i vec je zakljucena lista ucesnika Link to comment Podeli na ovim sajtovima More sharing options...
Zflazar Napisano Novembar 13, 2012 Share #4 Napisano Novembar 13, 2012 e, da je za vilosofski fakultet a ne za lektrotehnički, ne bi ti listu tek tako zaključio! Link to comment Podeli na ovim sajtovima More sharing options...
ZZZ Napisano Novembar 13, 2012 Share #5 Napisano Novembar 13, 2012 ujedno su i dali specifikacije i standarde koje bi trebalo da postuje tube amp(pomalo zaboravljeni parametri, narocito oni koji su vezani za osetljivost ulaza2V je ispravno)U par recenica su definisali dosta toga.ustvari ponovili ono sto je ranije bio neki standard pa je malo zaboravljeno...siguran sam da ce biti vrlo zanimljivo "takmicenje"Svaka cast. Link to comment Podeli na ovim sajtovima More sharing options...
