zeljkor
Sve objavljeno od zeljkor
  1. A da kupis ove i kanibalizujes za delove? Mozda bi mogao i da pregovaras oko cene. KupujemProdajem WWW.KUPUJEMPRODAJEM.COM Praktično sve... Kupi i prodaj u najvećoj online zajednici u Srbiji. Probaj na kp!
  2. Ako nisi nasao da imas. ES 80.pdf
  3. Onda jedino strpljivo cekanje na KP, pa kada se pojave.
  4. Pisi ljudima, verujem da ce pomoci koliko je moguce. Problem je sto su JBL rezervni delovi skupi + transport + carina + PDV...
  5. JBL 362830-001 Tweeter - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL 362830-001 Tweeter This is the ultra high frequency driver (UHF) Used in models: LC1, L810 ,L830, L880, L890, ES20, ES30, ES80, ES90, ES100 4 ohms Also used to replace parts 353107-001 and 362760-001. JBL ES Series Tweeter 79DM19AX-DT01-E - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL ES Series Tweeter. This includes the lower high-frequency unit and faceplate. Used in models:ES20, ES30, ES80, ES90, ES100 This unit is discontinued! You can purchase part 443574-001 as a direct replacement. This is the bottom tweeter in this assembly. The top tweeter unit (UHF) is 362830-001. JBL Control CRV Tweeter 443574-001 - The Speaker Exchange RECONINGSPEAKERS.COM Brand New Genuine JBL Control CRV Tweeter. 0.75″ titanium-laminate dome tweeter, shielded neodymium magnet, with ferrofluid for cooling. 4 ohms. Can be used to replace tweeter numbers: 362819-001, 338035-001, 905402-010, 335632-001 which are used in models NS28I, NS28II, Venue 80, ES30, ES80, P35E, P35ES, E100, Northridge E30, Northridge E50, Northridge...
  6. Napravio sam nove slike. Horne treba peskirati i lepo plastificirati ili ofarbati. Ovo je slika jedne, druga je identicna
  7. Preporucujem BSS, zaista je odlicna sprava, moze se naci povoljno na ebay sa karticama. Ja imam jedan digitalan, jedan analogan ulaz i dve analogna izlaza. SoundwebLondonBrochure.pdf
  8. Jos nesto mikrodetalji su neverovatni. Efikasnost kutija je negde cca 97-98dB. Takodje je dobro sto je veza sa PC direktno preko BLU linka koristeci BLU USB.
  9. Ja sam veoma zadovoljan. Ako poredimo sa 4345 kutijom , 4345 ima finiji bas u smislu da je zrnce bolje definisan ali puno manje energije ima u odnosu na ove nove kutije. Sredina puno bolja, midbas takodje. Iskreno ocekivao sam vise od ove horne, mislim da danas ima mozda i boljeg izbora. Zvucnici traze vecu sobu, sto je za ocekivati. Kada je u pitanju dinamika kutije izuvaju iz cipela. Treba razrada to stoji, ovo su sve ozbiljne pro jedinice.
  10. Nije 100% jer je bilo sitnih promena tokom izrade. MDF je u pitanju. Dampiranje rockwool 7cm + 2cm azmafon + vlatelin (nije svuda isto). kutija prednja ploca.pdf kutija presek sa bocne strane.pdf kutija presek sa gornje strane.pdf kutija presek sa prednje strane iznutra.pdf kutija zadnja ploca.pdf
  11. Detalji skretnice 2242 LR 48dB 290Hz 2202 LR 24dB 290Hz 1.4kHz 48dB LR 2451 Be 1.4kHz 48dB LR 8.5kHz 48dB LR + high shelf 12dB/oct od 4.5khz +6dB 2405 8.5kHz 24dB LR Ima i raznih PEQ ali manje vise to je setovanje.
  12. Mereno sa Omnimic V2 od Dayton Audio na 1m razdaljine i gate-ingom.
  13. Malo vise detalja - sve je aktivno. Skretnica BSS BLU160, pojacalo Crown CT875. Svaki driver poseban kanal. Aniti HiFi sistem po konceptu
  14. 2206.pdf
  15. 12" idealno u kombinaciju sa 2453 i WG.
  16. I datasheet 2251 Data.pdf
  17. Voditi racuna da su 16 Ohma. Neodijumski magneti.
  18. Ovaj WG ide u kutije: STX825 SRX812P SRX815P VTX-F12 VTX-F15
  19. Sada sam se setio da sam uz ove drivere kupio i waveguide #5006815 koji ide u STX825. Tako da je ovo realno komplet i kao takav bi prodao. Podloske koje peglaju odziv idu gratis
  20. Takodje posle dugog vremena up. Moracu da napravim nove slike.
  21. NOS - prepucium
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 27 Gosta (Pogledaj celu listu)
    450.6k
    Alen
    Alen
