862 -
3
Postovi objavljeno od silentbob
Ne znam da li je vece pojacanje u ovom slucaju bitno, i koliko je na originalnim tranzistorima, ali racunam sto vise to bolje
Hvala, snasao sam se. Ostalo u ITC-u jos malo.
Kakav im je hfe? Jel imaju par ili samo jedan?
Pitam jer moj par 2SC2240/2SA970 ne prelazi 200.
Moze rezervacija do veceras? Moram da proverim da li se uklapaju sa ostatkom ...
Kada sam pre godinu dana kupovao TV 700Eur je i meni bila cifra koju sam spreman da izdvojim, gledao dugo po nasim prodavnicama, limit se polako blizio prema 1000Eur, a onda cuo za ljude koji donose televizore iz madjarske po istim cenama kao i tamo, sto je otprilike 40% nize nego ovde.
Kupio sam tada Samsung UE40D6500 za 690 EUR dok je u kod nas isti kostao 139000 RSD.
Naravno postoji odredjeni rizik sto se tice garancije, ali mislim da je opcija vredna razmatranja.
Kupio kolega sa foruma.
Moze lock sto se mene tice.
Nova cena 6000 dinara + PTT
Miso, koji sajt da odaberem na farnell.com? Jel export?
Ipak miris nije dolazio od kutije vec kao sto Nino rece od otpornika u RC filteru, sa snaznijim otporima nema mirisa
Koji su to drajveri/delovi u kitu tj. ko je proizvodjac?
http://www.tannoy.com/faq.aspx kaze:
Q. Can I buy individual parts from Tannoy like Drivers and Crossovers to build my own speakers? A. Unfortunately not. We at Tannoy realise that some of our customers like building their own speaker cabinets as a hobby, and even though several years ago we were happy to supply individual components, we have recently experienced problems when genuine Tannoy parts have been purchased, custom fitted into homemade cabinets and then sold on improperly as genuine Tannoy products. We can not supply schematic drawings or design information relating to our loudspeakers. If you already own a genuine Tannoy speaker that has been damaged then we will of course endeavour to supply spare parts in order to repair your speakers for as long as the parts are available.
Prodajem dva mono pojacavaca "Iskra TYP SEO 2706".
Ispravnost elektronike mi nije poznata, ali s obzirom da poslednjih 15 godina stoje na tavanu pretpostavljam da bih trebalo promeniti elektrolite.
Od vrednijih delova tu su mrezni trafo, izlazni trafo, izlazni tranzistori 2n6254 4kom po kanalu, TO-3 hladnjaci, kutija sa al prednjom plocom.
Spoljasnje dimenzije kutije su:
43 x 24 x 12 cm
Vise slika mozete pogledati ovde
Uz navedeno poklanjam i pretpojacalo sa slika.
Cena 80 Eur. U obzir dolaze i zamene. -
U F5 -V2 shemi sa diyaudio.com stoje 2SK370/2SJ108. Kakva je situacija sa njima? Jesu li "losiji" ili ih je takodje tesko nabaviti?
Da to bi moglo lepo da se iskoristi za B1 buffer.
Mislio sam da se eventualno moze iskoristiti jedan ili kupiti LSK170 ali sad vidim da linearsystems ne prave P kanalne nesto kao LSJ71
Polako zavrsavam F5, ali ne mogu nigde da nadjem 2sj74. Pronasao sam uparene 2sk170/2sj74 u Hong Kong-u, ali mogucnost placanja je samo PAYPAL, tako da to odpada. Interesuje me, sta bih mogao da iskoristim kao zamenu za ova dva jfet-a?
Sta je sa ovim LSK389?
Sto jes jes, ali mi je cudno sto se pomeranjem zica bas nista ne menja, konkretno ove od prekidaca sam bio skroz izbacio.Slazem se da sam mogao biti malo uredniji, ali sa ovom plocicom gde su izlazni tranzistori van ja bolje ne umem.Nego, nasao sam na diyaudio.com dosta tema u vezi hirage i bruma, neki kazu da je dizajin PCB-a los i da su ostavili nekoliko stotina sati pokusavajuci da rese zujanje bez uspeha, drugi kazu da je malo bolje ako se koristi SMPS napajanje ...Sve u svemu mislim da cu ostaviti ovako kako jeste dok se nakanim da sastavim tvoj F5 i ubacim umesto hirage, tad cu valjda biti malo uredniji.Kad bolje razmislim nije taj brum toliko strasan na mojim zvucnicima od 85db.Mnogo si Dragance rasteglio te zice
Eh, lako je kad si majstor :respect:U svakom slucaju hvala svima na dobroj volji i pomoci.Гледај како су то мајстори радили и копирај их.
Posto sam od skoro vlasnik ovog DAC-a moram da kazem da i ja imam slicne utiske. Recimo da mi se mnogo mi se vise svidja nego rDac koji sam prethodno slusao.Hvala na ovoj temi jer mi je dosta pomogla da se odlucim za kupovinu.Ono sto me zanima je da li si primetio pojavu DC napona (oko 2v) na izlazu prilikom ukljucenja? S obzirom da sam dac kupio polovan a prethodni vlasnik ga je sklopio iz kit-a pokusavam da shvatim da li je ova pojava posledica lose izvedbe ili default ponasanje ovih uredjaja.dac koji je ispunio sva moja ocekivanja
Hiraga dobila novo napajanje ali brum je i dalje tu
Sve je manje-vise povezano kao i pre ...
Nova stvar koju sam primetio je da kada je povezan na dac brum se cuje na jednom kanalu koji se menja kada promenim mesto kablovima. Sa kompa se cuje na oba.
Takodje, kada masu sa cinca prespojim na uzemljenje cuje se jos jedan brum druge frekvencije, mislim da je 50hz.
jos slika ovde
monty alexander trio - nite mist blue [/font]
flac obavezno![/font]
Cestitam , stvarno izgledaju vrhunski, a verujem da isto tako i zvuce.Ako nije nekulturno pitati, koliko okvirno kosta materijal za ovaj projekat? (kutija, drajveri, skretnica ....)
Narucio sam elektrolite manjeg napona i dimenzija koje cu da montiram na PCB, ovi su mnogo nezgodni za pomeranje po kutiji.Inace, kada sam ga povezao na DAC sa malo boljim kablovima brum se znatno smanjio.Javljam rezultate sledece nedelje kad ugradim nove elektrolite.
Ko voli ...
Problem je sto se ne vide vodovi jer su ispod sivih elektrolita.
Evo dodao sam jos slika
https://plus.google....759653292854481
Narandzasti pravougaonik je parce pertinaksa na koji su zalemljene zice koje razvode audio masu i jedan kraj loop breaker-a. Srafovi prave kontakt sa kondenzarorima.
Mislim da se na ovom crtezu vidi bolje nego na slikama.
Na moju veliku zalost moram da ozivim ovu temu.
Kao novi vlasnik ovog pojacala uradio sam nekoliko prepravki na kutiji i brum je ponovo tu.
Evo o cemu se radi
Simptomi:
- cini mi se da je 100hz.
- brum postoji i kad su ulazi spojeni na masu ali podnosljivo vise lici na sum.
- kada su zakaceni samo kablovi bez source-a malo se pojaca.
- kada postoji source i samo jedan ulaz ustekan nista se ne menja
- kada su oba kanala zakacena na source brum se znatno poveca cuje se na 2m.
- postoji i kada se otkaci mrezno uzemljenje sa sasije.
- cim se iskljuci trafo brum nestaje, muzika se cuje jos 10-ak sekundi napajajuci se iz elektrolita.
Probao sam sledece:
- vise laptopova i diskmena kao source - bez promena.
- probao TV kao izvor - pojacao se jos vise. kada sam otkacio antenu vratio se na prethodni nivo. kao sa laptopom.
- svejedno je da li laptop kao izvor radi na uzemljenom punjacu ili bateriji.
- izbacivanje mreznog filtera - nista.
- vodjenje ulazne mase uz minus zvucnika do audio mase (centralne) i nazad kao sto je Impuls ranije rekao. - postoji promena u zavisnosti od polozaja kabla ali nedovoljno.
- da otkacim masu na jednom ulazu - na jednom kanalu se brum smanji na drugom pojaca. ukupan nivo isti.
- da kratko spojim minus zvucnika i ulaza - isto kao u prethodnom slucaju.
- stavio oklopljeni kabal za ulaz - isto.
Trenutno nemam ni jedan drugi source ali radim na tome da probam nesto drugo.
Napajanje oziceno po ovom principu samo sa 2 greca.
Ground Loop breaker napravljen sa otpornikom 5ohm i dve diode bez kondenzatora.
Evo i slika:
https://plus.google....737461668882177
Na slikama se ne vidi ali prepravio sam da minus zvucnika ide sa zajednicke audio mase.
Jel ima neko ideju sta jos da probam pre nego krenem da vadim trafo iz kutije.
Stvar ukusa, meni su bas zanimljivi.Mada, ako ti se ne svidja ova stvar verovatno nece ni ostale. .Možda je album dobar. Skinem pa poslušam, ali ovo sa spota je katastrofa na kvadrat.Nema uživanja ni za oko ni za uho. Degradirali su Rehab.
Trenutno na sajtu 0 članova, 0 Skrivenih, 462 Gosta (Pogledaj celu listu)
Ukupan broj tema435.5k
Polica za HiFi sprave
in Project gallery/WIKI
Lepo!
A ja bi nesto ovako
Jel imate ideju koliko je komplikovano napraviti? Meni se cini da nije previse, bar sto se tice sklapanja jer nema previse elemenata ...
Zocky izvini ako je OT.
