Compiling Handbrake on Debian & Ubuntu x265 10bit/12bit
Mogu da potvrdim da ovo radi na Debian Jessie & Ubuntu 16.x
Trebalo mi je dosta vremena da skontam ovo. Pogotovo za stariju verziju Debijana...
Kod:
apt-get update &&
apt-get install -y git cmake yasm build-essential autoconf libtool \
zlib1g-dev libbz2-dev libogg-dev libtheora-dev libvorbis-dev \
libsamplerate-dev libxml2-dev libfribidi-dev libfreetype6-dev \
libfontconfig1-dev libass-dev libmp3lame-dev libx264-dev libjansson-dev \
intltool libglib2.0-dev libdbus-glib-1-dev libgtk-3-dev libgudev-1.0-dev \
libwebkitgtk-3.0-dev libnotify-dev libgstreamer1.0-dev libopus-dev \
libgstreamer-plugins-base1.0-dev libappindicator-dev libtool-bin &&
apt-get install -y libmp3lame-dev libass-dev libsamplerate-dev &&
ldconfig &&
export PKG_CONFIG=/usr/bin/pkg-config &&
export PKG_CONFIG_PATH=/usr/lib/pkgconfig &&
git clone https://github.com/HandBrake/HandBrake.git hb-master &&
cp -n ./hb-master/contrib/m4/module.defs ./hb-master/contrib/m4/module.defs.bak &&
echo '$(eval $(call import.MODULE.defs,M4,m4))' > ./hb-master/contrib/m4/module.defs &&
echo '$(eval $(call import.CONTRIB.defs,M4))' >> ./hb-master/contrib/m4/module.defs &&
echo 'M4.FETCH.url = http://ftp.gnu.org/gnu/m4/m4-1.4.17.tar.bz2' >> ./hb-master/contrib/m4/module.defs &&
echo 'M4.FETCH.md5 = 8a1787edcba75ae5cd1dc40d7d8ed03a' >> ./hb-master/contrib/m4/module.defs &&
cd hb-master &&
./configure --enable-fdk-aac --enable-x265 --arch=x86_64 --optimize=speed &&
cd build &&
make &&
make install &&
cd gtk &&
make install &&
Sličan je princip i za ostale Linukse.
Ubaciti kod u whatever.sh i pokrenuti skriptu sa >bash whatever.sh
Kome treba enkodiranje video materijala sa zadnjim  x265 ovo je jedno od najboljih rešenja.
Instalira se zajedno i Handbrake CLI & GTK . . .;)
  • Odgovora 1
Popularni dani
Zašto 10bit.
Videti
https://gist.github.com/l4n9th4n9/4459997
i
Why does 10-bit save bandwidth (even when content is 8-bit)?
http://x264.nl/x264/10bit_02-ateme-why_does_10bit_save_bandwidth.pdf
Ako nekoga zanima i kako (dobro) izgleda 10bitni video imate ovde izložbu :
https://www.reddit.com/r/megalinks/search?q=10bit&sort=new&restrict_sr=on
 I'm staring at the 42" TV (4" distance) to see the defect. And I do not see it. looks the same like 4K  or  1080p :buehehe:
