khachai44 Napisano Maj 20, 2017 #1 Napisano Maj 20, 2017 Hi,I'd like to connect RME UCX line out to PA.The mixer is far away so I have to connect to stage box which has XLR inputs that go to Mixer Mic input.RME UCX line out specs:• Output: 6.3 mm TRS jack, servo-balanced• Output impedance: 75 Ohm• Output level switchable Hi Gain, +4 dBu, -10 dBV• Output level at 0 dBFS @ Hi Gain: +19 dBu• Output level at 0 dBFS @ +4 dBu: +13 dBu• Output level at 0 dBFS @ -10 dBV: +2 dBVI am not sure about the PA Mixer specs or even if it has Pad on inputs.I am sending full stereo mix, so don't want any artifacts like tonal shifts or loss of dynamics.What is the best way to connect this ?Is simply lowering output level going to work ?Do I need a DI Box ?
Zen Mod Napisano Maj 20, 2017 #2 Napisano Maj 20, 2017 source is having enough cojones to drive long trace but you really need to connect that line (high level) to appropriate input in PA Mix , to preserve dynamics worse case would be using custom balanced attenuator box or balanced to balanced DI Box , but you can still do that in any case - long trace must stay balanced
Kuja Napisano Maj 22, 2017 #3 Napisano Maj 22, 2017 ... https://www.gearslutz.com/board/live-sound/1153530-connecting-interface-line-out-into-stage-box-mic.html ... http://www.hi-files.com/forum/index.php?/topic/31087-i-need-some-advice-of-coloringsaturation-gear-w-midas-m32r/ https://www.gearslutz.com/board/live-sound/1153196-need-advise-buying-dedicated-monitoring-rack.html Autori originalnih tema na Gearslutz forumu... ?
