grone Napisano Februar 9, 2017 #1 Napisano Februar 9, 2017 http://www.jp.onkyo.com/audiovisual/smartphone/granbeat/ Aleks je reagovao/la na ovo 1
Aleks Napisano Februar 9, 2017 #2 Napisano Februar 9, 2017 Hehe Pitanje trenutka kada ce svi pametni telefoni davati digitalni izlaz..
silentbob Napisano Februar 9, 2017 #3 Napisano Februar 9, 2017 Ali nece svi imati kvalitetan dac unutra. U ovaj su ubacili ES9018. Zna li mu se cena? Ranije sam vidjao neke sa AK4xxx dacovima ali cena je bili oko 500$.
sir Oliver Napisano Februar 9, 2017 #4 Napisano Februar 9, 2017 17 minutes ago, Alex said: Hehe Pitanje trenutka kada ce svi pametni telefoni davati digitalni izlaz.. Valjda od Androida 5.0 je to podržano? Na mom soniju: To play high-resolution audio via the micro USB port From the Home screen, tap . Find and tap Settings > Sound > Audio settings. Mark the Hi-Res Audio via USB checkbox. Using a USB cable, connect your device to one of the following device types: a portable digital-to-analog converter/amplifier (DAC/amp) device, for example, the Sony PHA-2 Portable Hi-Res DAC/Headphone Amplifier. the high-resolution player/amplifier unit (DAC/amp) of a home entertainment/sound system, for example, the Sony MAP-S1or Sony TA-A1ES. Make sure the amplifier is connected to a set of speakers or headphones. Using the relevant application in your device, play the audio or video file that you want to listen to in high-resolution.
grone Napisano Februar 9, 2017 Autor #5 Napisano Februar 9, 2017 10 minutes ago, silentbob said: Ali nece svi imati kvalitetan dac unutra. U ovaj su ubacili ES9018. Zna li mu se cena? Ranije sam vidjao neke sa AK4xxx dacovima ali cena je bili oko 500$. 700$ po ovom: http://www.pdevice.com/product/onkyo-granbeat-specs
