Americki Izlazni PP trafo LS-54 za 6l6,6V6,5881,6BQ5,6AQ5
Izlazni PP trafo ,8Kohma primar, sekundar 30,20,15,10,7.5,5,2,5 ohma,20W marke UTC -United Transformer Corporation New York ,USA type LS-54 za neko gitarsko pojacalo,ekstra.Evo na stranjskom>One Used UTC Output Transformers LS-54. Dimensions are 4 1/4" x 3 1/4" x 4 3/4". Net weight 7.2 lbs/3.3kg. The specs from an old UTC catalog : Use : Output Transformer To Line and Voice Coil. Application : Push Pull 245, 250, 6V6, 42, 2A5 Tubes. Primary Impedance : 8,000 Ohms. Secondary : 30, 20, 15, 10, 7.5, 5.0, 2.5, 1.2 +/- 1 db from : 30-20,000 Max. Level : +36DB Guarantee Good Output Transformercena:40 eura ,na PP dogovor
  • 3 months later...
  • Odgovora 5
Evo da dodam neku semu za instrumentalno pojacalo koje je FENDER radio i gde bi mogao ovaj trafo da ide bez problema.model:FENDER GA-6 Lancer, 14W 2x12" ComboThis amp replaced the BR-6. The circuit is identical to that of the GA-14.Schematic with 2x 12AX7, 2x 6V6 & 1x 5Y3 Prodajem i lampe: 6V6 par ruskih,ECC83 par EI i 5Y3 sa 3 oktal podnozja,dva noval zajedno sa izlaznim trafoom samo u kompletu 80 eura.Za ostalo snadjite se sami.
idi begaj Dunavko :frusty:di mu je brat - za Stereo ?
