Dmeister
Sve objavljeno od Dmeister
  1. Dmeister
    Kupujem ECC88
    moze lock
  2. Dmeister
    Kupujem ECC88
    I dalje aktuelan oglas
  3. Probajte drugari, jako je zanimljiv efekat, a pet minuta posla povezati zvucnik.
  4. "What seems to happen is that the third speaker reproduces any sound that is not common to both sides of the stereo - i.e., everything that is not located centrally in the stereo image - and I assume that this is because the common information is put out of phase with itself and cancels out." Znaci, treci zvucnik reprodukuje sve osim zvuka koji je u centru zvucne slike.
  5. Upravo tako. Ne verujem da pravi probleme pri relativno manjim snagama. Povezao sam ga na noviji Rotel od 40W po kanalu, slusao i preko pola jacine, ne pravi probleme, ne greje se previse.
  6. Pozdrav dragi forumasi. U potrazi za nacrtima za omnidirekcione zvucnike, naidjoh na ovaj clanak koji je napisao Brian Eno. pa kaze: However, I have for many years been using a three-way speaker system that is both simple to install and inexpensive, and which seems to work very well on any music with a broad stereo image. The effect is subtle but definite - it opens out the music and seems to enlarge the room acoustically. ceo clanak ovde: http://music.hyperreal.org/artists/brian_eno/onland-txt.html Sustina toga jeste povezati treci zvucnik, pozeljno neke vece impedanse i manjih dimenzija od glavnih zvucnika, i staviti ga iza. Ovako se povezuje : Rezultat koji sam ja dobio sa starim Ei dvosistemskim zvucnikom je jako prijatan i zanimljiv, i daje dosta prostora zvuku. Daje iluziju vece sobe. Probajte pa recite sta mislite, ili recite ako ste vec imali iskustva sa ovakvim povezivanjem.
  7. Dmeister
    P: Nekoliko ploca
    i dalje aktuelno. 063 727 8024 David.
  8. Dmeister
    P: Nekoliko ploca
    Parni Valjak - Sizofrenik/Parni Valjak Prvi singl iz 1976. grupe Parni Valjak. Ocuvana ploca. 500 din. B.B. King - Live at The Regal Reizdanje cuvenog live albuma, ploca kupljena nova, samo par puta slusana. 1300 din. Pet Shop Boys - West End Girls Nemacko izdanje maxi singla West End Girls. Ocuvana ploca. 500 din. Licno preuzimanje u Nisu, ili slanje kurirskom sluzbom, postarinu placa kupac. 063 727 8024 David.
  9. ima li neko visak fullrange zvucnjaka? potrebni mladom clanu za open-baffle eksperimentaciju
  10. ostale samo macije oci
  11. Prodajem NOS, potpuno nekoriscene lampe. Macije oci, odlicne za projekat za vu-metar: Dve EM84 - Tesla i Ei Nis - cena za komad - 5 evra Jedna EM80 - Ei Nis - 5 evra Cena za sve tri - 10 evra. Philipsove gasne stabilizatorke OD3 i poznate Ei Nis pentode EL84: EL84 par - 20 evra. OD3 par - 20 evra. Sve zajedno - 30 evra. 063/727-8024 David. Licno preuzimanje u Nisu ili slanje kurirskom sluzbom, postarinu placa kupac. slike ovde:http://www.kupujemprodajem.com/NOS-lampe-OD3-i-EL84-5611981-oglas.htm http://www.kupujemprodajem.com/NOS-macije-oci-lampe-EM80-EM84-5615166-oglas.htm
  12. Dmeister
    Prodajem Tannoy M15
    otisli zvucnici, moze kljuc.
  13. Dmeister
    Kupujem ECC88
    Boga mi, postena cena. Kad je berza?
  14. Dmeister
    Kupujem ECC88
    Kupujem dve NOS ECC88 lampe. Posaljite ponude u inbox ili na br. 063/ 727-8024. David.
  15. Dmeister
    Prodajem Tannoy M15
    aktuelno, moze i zamena za neke combo orgulje
  16. Dmeister
    Prodajem Tannoy M15
    i dalje aktuelno, dajte neku razumnu ponudu
  17. Dmeister
    Prodajem Tannoy M15
    aktuelno
  18. Dmeister
    Prodajem Tannoy M15
    oh boze , nisam ni primetio, hvala na korekciji!
  19. Prodajem zvucnike Tannoy M15. Ocuvani, nikada popravljani, oba drajvera fabricka, ne premotavana. Mogucnost bi-wireing-a. Par sitnih ogrebotina i manjih fleka na mrezicama, nista ozbiljno. Mogucnost slusanja u Nisu. Licno preuzimanje u Nisu ili slanje kurirskom sluzbom na trosak kupca. Cena 120e, nije fiksno. Slike ovde: http://www.kupujemprodajem.com/Tannoy-M15-4494397-oglas.htm
  20. Svejedno, samo da ima svoje malo pojacalo i zvucnik i da svira
  21. Pozdrav svima! Kupujem prenosni gramofon - znaci napajanje baterije. Nebitan model i proizvodjac. Samo da je potpuno ispravan. Cena - dogovor, ili zamena za komponente.
  22. Step-up trafo za MC glave, ako sam dobro razumeo.
  23. slusa se Chet Baker na kolega Saletovom 6v6 pojacalu, uzivancija!
  24. Preporucite neki album sa odlicnom zvucnom slikom
    1. zerowaf
      zerowaf
      Ne kontam?! Kako to misliš?
      Ako hoćeš naglašen prostor između instrumenata u stereo izvedbi možeš uzeti skoro svaki sampler koji je potpisan od nekog proizvođača hife. Hint: U naslovu vjerojatno ima "Audiophile" nešto. Pao mi sad na pamet "Jazz at the pawnshop" - snimak koji je slučajno ispao takav da je pozornica jako životna.
    2. stein
      stein
      Jel može ta slika da bude u jpg formatu? to ima svaki CD iz City produkcije :)
    3. mrcelavi
      mrcelavi
      Roger Waters Amuset to death
  25. Ako se razumes, probaj da zamenis elektrolike i tu osamdeset-peticu
  • Trenutno na sajtu   0 članova, 1 Skrivenih, 81 Gosta (Pogledaj celu listu)
    450.7k
    Alen
    Alen
