deki
Sve objavljeno od deki
  1. Prodajem nove cevi regulatorke napona WF str150 iliti OA2 33komada cena 100 dinara komad.
  2. deki
    nos lampe 6C19P-V
    Prodajem nove nekoriscene lampe 6C19P-V gold grid. 100komada, cena 150dinara komad 063 1183404
  3. deki
    6L6GC nos kvartet
    Nema ih vise . lampe prodate.
  4. deki
    6L6GC nos kvartet
    Kvartet 6L6GC low hours Phiips ecg a ustvari GE sa znakom na staklu 6L6GC made in usa . Test na 250V anoda 250V G2 i minus 14V G1 fiksni bias a ne katodni otpornik,tri komada 80mA jedan momad 70mA . 100% je 72mA ,sve su odlicne ,uz njih jedna EI 6L6GC testira 67mA. Geteri sjajni nema dima na staklu nema rupa u geteru nisu faded ,lampe su radile oko 100 sati u Mesa boogie pre 10 godina i ostavljene sa pojacalom Cena dogovor,uz kvartet EI je gratis. Dejan. 063 1183404
  5. I mozda na kraju price o ovoj cevi da dodam,u Holandiji su napravili test pojacalo sa njom i poslali mi komentare : Yes! i have built a single ended with them (together with my colleague/friend Miquel who also works here). We ran into the tubes needing very large swing (380V p-p) for about 6W output..... Because that would make the amp quite complex (or an expensive IT was needed) we decided to just use an EC86 and then go into the 400B (!) this gives approx 3,5 watts, but i do not think anyone will hear the difference between 3,5 and 6W. The amp has separate supplies for power stage and pre-stage, no feedback ofcourse.... i am using normal resistors for anode load of the EC86, but i found very nice russian military carbon composite resistors of 10W(!) They are quite big.....10cm,x2cm for a 10W resistor(!) these sound very very good!
  6. Inace nekoliko cevi su testirane i evo detalja o tom "projektu" Krive i podaci su zanimljivi. I attach the curves of it. Except for transconductance and gain are a bit too low. This could have been a product, like a low cost power triode. 300B-Experimental-by-EI-testdata (1).pdf 300B-Experimental-by-EI-Curves.pdf
  7. Jos par reci. U tu fabriku cevi su vise puta dolazili i cak ucestvovali savetima probama itd mnogi poznati iz sveta lampi i proizvodjaca pojacala,Ana Manely,Rojer Mojeski,Tim de Pavaracini ,vlasnik Jadisa. Inace to je bio isplativ niznis,prva kolicina KT90 za USA je bila 10000 komada po ceni 14$ komad. Sigurno da proizvodna cena jedne KT90 ,manje od 100 grama metala i stakla je manja od 14$ . U jedan kombi stane 10000 cevi puta 14$ ..... Imali su buducnost ali je nekom bilo u interesu da ne postoje vise kao i mnoge druge fabrike . Iako je to bila drzavna fabrika,bilo je ljudi spremnih da naprave nesto novo,Recimo na zahtev Mike Mahewsa napravili su probnu seriju klona indirektno grejane triode sa karakteristikama 300B. Evo price Mathewsa i par slika kako je izgledala ta cev uslovno nazvana 400B ,40W disipacije. > > I tried to interest the engineer at Ei to build > > an indirectly heated triode about like the > > 300B, but packaged like the KT90, as a drop > > in replacement for existing amps say with > > EL34, and the guy said he was working on > > what they said was a 400B prototype, > > but nothing has come of any of this afaik.
  8. Umalo da zaboravim,ova mermerna ploca je postavljena na fabriku prilikom otvaranja,jos uvek postoji a moze da ostane i posluzi kao nadrgrobna ploca nazalost.
  9. Da bi se bolje razumelo kako je sve pocelo 1952ge obavezno pogledati sledeci link,tada je drzava (sta to bese) dovela americke strucnjake da pogledaju fabriku i daju savete i organizuju dalju proizvodnju,sve je pocelo sa ratnim trofejnim masinama,tek kasnije je kupljena Philips tehnologija,tekst koji je nekad bio tajna objavljen je u USA. Jako zanimljivo: http://www.triodeel.com/hobbs.txt
  10. Evo nadjoh jos par tuznih slika iz 2013te ,evo kako je tada izgledalo postrojenje ocerupane masine preostale posle iznosenja WE masina ,prakticno sve povadjeno i razneseno verovatno tokom noci. Slika sobe sa gusto poredjanim "stanicama" za varenje delova lampi,stotine zena je sedelo tesno zbijenih ,svaka stanica je imala sistem za tackasto varenje aktivacija pedalom. Dve elektrode i velika lupa iznad njih,ima ove slike na snimku koji je ovde ,dok je fabrika radila. Soba sa nekoliko desetina hiljada lampi u stiropor pakovanju ,uglavnom tv i pcc189.
  11. Pozdrav Te slike kod Jacmusic sam ja napravio 2010te. Tako je sve stajalo do 2013 te novembra kada su masine koje je Whitener kupio iznesene a ostatak ,skoro polovina je zavrsio na aukciji u samoj fabrici po ceni starog gvozdja. A inace slike su samo iz finalnog dela proizvodnje i testiranja,sama fabrika je bila ogromna ,posebni delovi za sastavljanje cei i motanje resetki nisu prikazani,naci cu slike te ih okaciti. Inace same masine koje je WE kupio su jos u Nisu u jednom privatnom magacinu ,stoje i cekaju dalju sudbinu. Ko zna da li ce uopste ista od svega to biti ponovo u funkciji.
  12. deki
    C jezgra trafoi
    Ako ce da pomogne,evo izgleda bez pribora za montazu. debljina preko laminata je 23mm ,sirina limova 40mm,skoro 10kvadratica. Visina trafoa je 125mm.
  13. deki
    C jezgra trafoi
    Ima ,otici cu kod Dual antena,on ima merac,gledacu sutra da to uradim. Ne verujem da je visok,zica je debela bas ali videcemo.
  14. deki
    C jezgra trafoi
    Prodajem 4 Iskra C jezgra. Snazne prigusnice 2mm zica. Limovi 0.3mm . Jednoztruko jezgro je 8 kvadrata,dvostruko 16. Visina jezgra 125mm,Sirina limova 40mm ,debljina preko laminata 22mm. Novo nerasturano. Cena dogovor.
  15. Epkosa vise nema,prodati. Iskre ostale 200dinara komad nova cena.
  16. Prodajem nos Epcos i Iskra elektrolite 4700mF 100V. Epcos 500dinara komad Iskra 300din komad.
  17. Nos nekorisceni kondenzatori metal papir 2mF 1200V radni napon idealni za samogradnju i audio.Dimenzije 5x4cm. Cena dogovor.
  18. deki
    6HM5 nove cevi
    6HM5 nove lampe 120 din komad ,za vise komada cena po dogovoru. 063 1183404
  19. deki
    6GH8A nove lampe
    6GH8A nove lampe,cena 140 din komad ,za vise komada cena po dogovoru. 063 1183404
  20. deki
    Siemens PIO MP kondenatori
    Nema vise,prodato.
  21. Prodajem 4 komada Siemens MP metalizirani papir u ulju 8mF 630V ,dimenzije 1000mmx35mm. Cena dogovor. 063 1183404
  22. deki
    Lampe EI PY88 veca kolicina
    PY88 nove 300komada ,prodajem svih 300 lampi za samo 8000 dinara. 0631183404
  23. deki
    Prigusnice Siemens
    Prugusnice su prodate .
  24. deki
    Prigusnice Siemens
    Prodajem 4 komada Siemens prigusnica na M jezgru, dimenzije jezgra su 65x65x28mm presek 6kvadrata ,otpor 3 oma , induktivnost 180milihenrija. Cena dogovor. 063 1183404
  25. Prodajem vecu kolicinu novih EI PY88 lampi,cena povoljna po dogovoru. 063 1183404
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 599 Gosta (Pogledaj celu listu)
    454.9k
