Lemur
Član-
39 -
Sve objavljeno od Lemur
Hvala al meni bas treba V5i Dual
Kupio bih Burson v5i dual, singl Opamp, ako neko ima viska
SMSL M8A Native ES9028Q2M DSD512/PCM768kHz USB DAC OPTICAL/Coaxial /USB Input RCA Output Cena: 120 eur Uz DAC ide USB kabl i njegovo fabricko napajanje. Kontakt: 060/8655401
HRT Music Streamer II DAC Data Rate: up to 96 khz Sample Depth: up to 24 bit Transfer Protocol: Asynchronous Asinhroni USB ulaz, RCA izlaz, napajanje preko USB kabla. Kupljen nov u Srbiji Made in USA Cena: 70 eur Kontakt: 0608655401
Aktuelan nova cena 12 hiljada
Cena podlozna dogovoru Moguce davanje na probu
Nova forumska cena 150 eura Moguce davanje na probu
Na prodaju Preamp kupljen ovde na forumu - Sipijev MOSFET Mju follower Vise informacija na topicu Placen 16.000 Prodajna cena - ajde 15.000 060/8655401
Na prodaju AVM Vorstufe preamp 2 x tape IN / OUT Phono MM / MC CD AUX tuner 2 x OUT Made in West Germany ;-) Radio kod mene skoro 10 godina U dobrom stanju, sredjene sitne falinke kod majstor Gox-a i apgrejdovan na OPA2134 Cena 200 evra 060/8655401
Samsungov LCD televizor diagonale 37 model LE37C530 2010 godiste Stanje besprekorno Nema stand, samo montaza na zid Cena: EUR 100.00 Kontakt: Milutin 060/8655401
DC powered, na to mi se odma spusta... nivo raspolozenja
Dragi forumasi, Ovih dana sam nesto gledao ponudu kineskih DACova na ALIexpress-u, za neku razumnu cifru do 200 eur ili ti dve glave... Pa sam izdvojio sledece reprezentativne primerke https://www.aliexpress.com/item/Finished-DAC7-parallel-dual-WM8741-WM8805-CM6631A-AD627-Audio-DAC/2055162863.html?spm=2114.01010208.3.114.4wlMUn&ws_ab_test=searchweb0_0,searchweb201602_3_10056_10065_10055_10068_10054_10069_10059_10073_10017_10070_10060_10061_10052_10062_10053_10050_10051,searchweb201603_3&btsid=d5b60c19-f07c-472f-9b59-dac42c8cd4a6 https://www.aliexpress.com/item/Finished-aquarius-PCM1794-AK4118-OPA2604-Top-Audio-DAC-cl134/32247675937.html?spm=2114.10010108.1000013.2.6ZAFkz&scm=1007.13339.33317.0&pvid=87bba8e0-2a9b-428d-90f5-b712279167fb&tpp=1 https://www.aliexpress.com/item/TOP-AK4495-XMOS-ADUM-High-Speed-Digital-isolation-Asynchronous-USB-DAC-decoder/32697280470.html?spm=2114.10010108.1000013.7.KjiGCa&scm=1007.13339.33317.0&pvid=88312c3f-eb1e-4805-87de-57505484f9ec&tpp=1 https://www.aliexpress.com/item/Finished-CS8416-WM8741-OPA2134PA-Audio-DAC-L153-22-HL/32320592778.html?spm=2114.01010208.3.42.xCr5mk&ws_ab_test=searchweb0_0,searchweb201602_3_10056_10065_10055_10068_10054_10069_10059_10073_10017_10070_10060_10061_10052_10062_10053_10050_10051,searchweb201603_3&btsid=019918d4-51e8-49f0-ad7f-d5749ebf6252 Da li je neko mozda slusao nekog od ovih zmajeva ili ima neku predstavu kako ovo moze da zvuci
Evo i sta kazu zvanicnici In response to "Kawai_man" and specifically the comment "The only thing I dont like about the MS is that it uses USB power." While true that all versions of our Streamer line don't use an external power supply, calling them USB powered is very inaccurate. Let me attempt to explain. All of our Streamers use a highly sophisticated and completely isolated power supply design. The USB power is regenerated (not just filtered and regulated) via a completely isolated power stage. There is no coupling mechanism between the computer (host) and the Streamer (device) side of the products. In fact, there is isolation of both the power and the data to the DAC stage. This isolation results in complete break in the conduction path. Adding a battery (of for that matter, any other approach) would not result in any improvement as the device (Streamer) already provides this capability. To go a step further, even if one did use a battery, but not our approach, the results would be considerably inferior as there would still be a connection between the computer and the audio sides of the product (as is the case in all other approaches). If one is not inclined to simply accept the comment of a manufacturer, try this simple test. Put a DVM or similar on the device and try to measure any conduction between the USB connector and the analog output. We claim an isolation of greater then 20 Mega Ohm, which is true. What isn't as obvious is how much greater than 20M this isolation is. The fact is it is for all practical terms, infinite. This is a significant performance advantage and one that is unique to our products. In conclusion, the closing statement by "Kwai_man", specifically "Im sure this would really increase the sound quality" would be true for any other USB DAC, but not for one of our Streamers. Kevin Halverson CTO High Resolution Technologies, LLC
A sta mislite o ovoj dzidzi: http://www.ebay.de/itm/Elfidelity-USB-Power-Source-PC-HiFi-Pre-amplifier-Filter-for-USB-Audio-Device-/262480498473?hash=item3d1d0e8f29:g:yEkAAOSwgApW~eTp
Dragi Forumasi, Da li bi mogli da mi preporucite neko pristupacno resenje za baterijsko napajanje HRT Music Streamer II USB DAC-a koji inace koristi switchersko napajanje, odnosno napajanje od kompa. U obzir naravno dolaze i DIY varijante...
Moram ovako jel stein ne moze da primi vise ni jednu poruku... Jel moze neka zamena + neke parice. Imam Pilot zvucnike na oglasima na onom drugom forumu.
Prodajem podnostojeće zvučnike Pilot Standmonitor. U pitanju je 4-sistemski transmisioni zvučnik, deklarisan na 200/300w na 4ohm-a Konfiguracija drajvera je: bas 10' + bas/srednji 8' + srednji + visoki Više o zvučnicima na hifi forumu, ima i osebna tema prethodnog vlasnika http://www.hi-files.com/forum/index.php?/topic/10736-u-poseti-kod-scepanbg-a/ Zbog aktuelne ekonomske situacije cena: 300 evra Kontakt: 060/86-55-401
Van den Hul The First interkonekt menjam za Neotech NEI 3001 ili prodajem (70 eur) Samo SMS na 060/86-55-401
Gde mu je atenuator? Ispravljeno... Odvojeno je pitanje @Lemur-a od navoda koji je koristio... Takođe su uklonjene slike iz navoda pošto su prisutne u post-u neposredno iznad...
Na prodaju: Cambridge Audio 640P, gramofonsko pretpojačalo Uz predpojačalo originalna futrola, kutija i račun iz Radixa gde je sprava kupljena Cena: okruglo 100 eur fiksno Slike su sa interneta, moj primerak je isti (dakle crni). Kontakt telefon: 064/261-09-54
Na prodaju: Harman/Kardon PM 665 dual mono integralno pojačalo Pojačalo je očuvano i potpuno ispravno, pregledano u servisu, napon i mirna struja su izmereni i podešeni. Predstavlja perijanicu tadašnje ponude firme Harman/Kardon i zajedno sa modelom Vxi poslednje Harmanovo pojačalo urađeno u Twin powered tehnologiji, odnosno sa dva odvojena transformatora za levi i desni kanal. Iskustva u odnosu na Vxi model koji je usledio kasnije su da je PM 665 iako manje snage, daleko relaksiraniji u tonalitetu i prijatniji za slusanje. Snaga: 2x110W(8ohm), 2x187W(4ohm) Damping factor at 1khz: 88 High Current Capability: 74A Power Consumption: 550W (600VA) Utisci sa interneta: http://oldaudioarchi...o.htm?radio=229 http://theartofsound...ad.php?p=133767 Sličice sa interneta: http://www.le-laden....ker-1J-Garantie Razlog prodaje: Prelazak na pre/power kombinaciju Cena: okruglo 200 eur fiksno Slike mog primerka (bice ih još kad ga izvadim iz police): Slike unutrašnjosti sa interneta:
Malo vivisekcije nikad nije na odmet, sve su to jako dobra pojačala, ne verujem baš da bi današnja nova sprava od 1500 eur bila nešto specijalno bolja, pogotovo ne od Harmana pm665. A što se lampaša tiče, tu trebaju odgovarajući zvučnici i odgovarajuć ukus.
Poredio sam skoro Harmana pm665 sa Dayens Ecstasy IIb integralcem i Harmanom hk680, pa da napišem par utisakaOd prvog je pm665 dinamičniji i dosta muzikalniji u višeinstrumentalnoj muzici, sa nižim basem. S druge strane, Dayens ima precizniju zvučnu sliku, više detalja na visokima i prirodniji zvuk pojedinačnih instrumenata. Međutim čim se pusti dinamičnija, višeinstrumentalna (recimo rnr ili blues) muzika, bend počinje da zvuči kao na teškim drogama. Nakon nekoliko dana slušanja imao sam utisak, a to sam rekao i Z. Dobrinu, da bi u taj Ecstasy trebalo staviti više struje/snage/veći torus, šta god. Sve u svemu Ecstasy je sjajno pojačalo (pogotovo za te pare, kao i sve ostalo od Dayensa), ali ne briljira podjednako u svim vrstama muzike. Dok je za ozbiljnu muziku, Jazz, ambientalne i neke čisto akustične varijante bio primetno bolji od mog Harmana pm665, čim je zasviralo malo više instrumenata - gitara, bas gitata, perkusija i klavijature - Ecstasy se zagrcnuo, a pm665 zasijao. Što se tiče Harmana hk680 u pitanju je jedno od najpoznatijih Harmanovih integralnih pojačala ako ne i the najpoznatije - sa razlogom visoko cenjeno u audiofilskim krugovima. Slušao sam ga nekoliko dana i ustisci u odnosu na pm665 su da hk680 ima inferiornije - povučenije srednje područije sa manje detalja i prilično dvodimenzionalnu zvučnu sliku. Na basu je izražen tzv. attack, odnosno slam ali je generalno bas područije, iako nije prenaglašeno, izvučeno iz cele zvučne slike i postavljeno kao dominantno - što se meni ne sviđa. S druge strane, hk680 na prvo slušanje zvuči donekle rafinisanije u odnosu na pm665, bas je zavodljivo napadan, srednji lepo postavljeni sa dobrom separacijom instrumenata, a visoki prisutniji i sa više detalja u odnosu na pm665. Međutim, nije potrebno dugo da se shvati da celom srednjem područiju nedostaje tzv. presence i da je povučeno u zvučnike, odnosno stvara utisak dopiranja iz kutija, a ne materijalizacije u prostoru. Takođe, bas iako na prvi utisak jako zavodljiv svojim slam-om, na duže staze stvara utisak izvučenosti iz konteksta. Generalno, dok se raspored instrumenata kod pm665 oseti u prostoru po dubini, kod hk680 od toga nema ništa.
Trenutno na sajtu 4 članova, 1 Skrivenih, 152 Gosta (Pogledaj celu listu)
Ukupan broj tema450.7k
