  • unosa
    87
  • komentara
    338
  • pregledâ
    121907
Tannoy K3809 - hardened cloth surround issue - solved
I'm lazy , so there are excerpts from my correspondence on Tannoy Yahoo group; all quotes - Mighty ZM :smesna:
I'm putting this here as future reference for some other desperate Tanner ; I must admit ( or I'm just boasting ) - I'm always having serius backup for all things speakers - from Aleksandar RAAL ....... even if I'm always stubborn and I'm bugging him only post hoc ..... to be sure that I didn't blew something :rofl:
Quote
K3809 - cloth surround impregnation solvent ?
as I wrote - pair of K3809
cloth surround , no back cone ribs
Fs is high - around 70Hz on both drivers
I contacted Tannoy Support , but they can't help - all they can recommend is
reconing , which is out of possibility , counting on fact that drivers are in
excellent condition and just slightly used (well - same as they aren't used at
all )
so - anyone having real life experience , regarding solvent for surround
impregnation ?
whatever , guy at http://www.haslingaudio.com is doing exactly the same for SH
Altec's , so I think same is possible for Tanns
TIA
Quote
Tnx for reply ;
There is no particular info on Altec related link , but point was that planned
procedure was implemented ...... I sent e-mail to Danish guy , asking for his
recipe , if nothing else , as starting point .
Whatever - K3808 (3809) are having impregnated cloth surround , not paper ;
that's visible on many pictures on net , and "cloth surround" is having exactly
that name in related info
In any case , if I succeed in "operation" , I'll share my findings
of course - "Danish guy " wasn't prepared to share his recipe ; I don't blame him ;)
that's why I'm sharing mine :rofl:
Quote
besides Sam R's problem with teared surround ......... and strictly speaking of hardened cloth surround - I'm stubborn and there is no way I'm going to change them .....
I would go to generic soft (probably acquired from Sonido guys in Hungary )
cloth surround , but will ever never invest money in new cones or - God forbid!
- neoprene surrounds ;)
I remember some guys at Diyaudio speaking of
http://en.wikipedia.org/wiki/2-Butoxyethanol , so I plan to start with that
Quote
Hardened cloth surround problem solved !!
soaking both sides of surround , using small brush , with plain Ethanol 95-96% ,
brought Fs from 71Hz to 29Hz .
I'm expecting that Fs will rise to spec. 35Hz , when solvent evaporate
That's what we are calling just Pure Alcohol , and you can buy it in every
drugstore.
So much speaking of recone and surround replacement ;)
Quote
I'll keep you informed , of course ;
even in case that Fs start rising again , I'll just repeat procedure , removing
old impregnation as much I can , and brush new tacky layer above it
then it will permanent solution
no damage , certainly ;
I'll post few pics in few days , after having definitive conclusion about
longevity of cure
Quote
Update : after 24h rest and solvent evaporated - two steps forward , one step back ;)
steps forward are :
1 - impregnate is not brittle and cracked (inducing noise , especially
detectable at Fs)
2 - everything looks just nice , almost as new
step back - Fs is back on 71Hz ;))
whatever , I'll proceed with more cleaning of old impregnate , and then try to
seal it with tacky surround goo , which will (hopefully) prevent repeated
hardening
will keep you informed
Quote
OK
K3809 - cloth surround impregnation solvent ; hardened cloth surround - high Fs - issue SOLVED
procedure finished and confirmed
after 24h (and more ) of solvents evaporating , Fs is still good : 33-35Hz
RECIPE
what you need :
1.small brush , semi hard m ~8mm wide , same as kids are using for painting in
school
2.Ethanol 95% (pure alcohol)
3.Acetone with oil ( nothing else than nail polish remover )
4.mouse glue (yes , that organic everlasting sticky goo)
5.Vaseline
6.cotton cloth ( old T shirt or whatever)
brush - buy it anywhere , mouse glue - anywhere , everything else - nearest drugstore
important to say - surround was originally threated from upper side , mostly ;
just slight residue of original rubbery impregnate is visible from bottom side
of surround
procedure for upper side of surround:
using brush - from upper side - soak surround with ethanol ; it's best to soak
it in parcels of 10cm , then rub it with same brush ; whenever you fill brush
with residue , wipe it on cloth
repeat procedure until you make two full circles (so entire surround perimeter
is twice treated)
move to second speaker ,same procedure , again two circles ;
repeat same soak-rub-wipe-soak-rub-wipe procedure on both speakers , until you can see clear fabric of cloth , without any trace of rubber
it's fun , but only if you have some muzak and coffee ;)
after few steps in procedure you'll see what's happening ; if you think that
you'll gain anything with another soak-rub-wipe circle , just do it
leave speakers 12h , to let Ethanol to evaporate
now - put some mouse glue on small (coffee cup) plate , add acetone and dissolve it to something liquid as milk
using brush - put that mixture on upper side of surround ; if you see that your
mixture on plate is going firmer , add acetone and mix ; when you treat entire
surround , take just acetone with brush and treat entire ( already impregnated )
area with it , to make it more uniform
leave it for 12h
now - bottom side of surround :
soak brush in acetone , rub it firmly in Vaseline , then put that mixture on
entire bottom side area ; goal is to have tiny layer of vaseline on bottom side
leave it 12h
measure Fs
easiest way of measuring Fs - use sine signal generator with 50R output
impedance , connect it to bass terminals , put CRO probes on terminals
sweep frequency from 100Hz down ; when you see biggest sine amplitude , there is Fs
another possibility for measuring - instead of sig gene - use Sig Jenny program
( wave gene with counter ) , sound card to small amp , amp to bass terminals ,
AC voltmeter to terminals
put few volts of sine to bass , sweep from 100Hz down , when you see biggest
reading on Vac meter , that is it
mine are at 31 and 33 Hz , I'm not loosing sleep because of using mouse glue and
vaseline on piece of cloth ;)
Quote
then one guy is saying that Mouse Glue is forbidden in some EU countries ; my reply :
Quote
in that case - just buy softest surround impregnation goop ; easy to do on line
, if living in Europe
unfortunately - Serbia , where I'm living - somehow isn't in Europe , so I'm
Paypal-less ;)
that means that I'm just lazy to chase soft surround impregnation goop from
Europe , taking in account that there is no domestic one
then guy asked where to search for surround impregnation goop ;
my reply :
Quote
sorry - just google ;
search for something like this : http://tinyurl.com/cw3yc8v
but , it's wise to buy only after confirmation from seller that really soft
thing is in question
Zen Mod
then guy asked for difference sound-wise , pre and post procedure ; my reply :
Quote
sound-wise - taking in account that my pair is most mint pair I ever had
opportunity to even see (except surround condition - most probably as result of
no-usage for all long years ), I'm eager to say that they're sounding just as
proper pair of K3809 ;)
right now being in stage of preparation of making boxes for them , I'm having
fresh experience just listening them in bafle-less iteration ; even like that ,
there is proper difference in bass , comparing to prior (surround treatment )
performance
whatever , fact that plain and common Ethanol is sufficiently good as solvent
for old impregnation , was nice surprise ....
Zen Mod
I hope you enjoyed little story :smesna:
In case that I remember to get cam to my workshop tomorrow , I'll make few pics and put it here , along with few pics of same drivers prior to fun procedure
edit : did I told ya that each cone got 2 layers of Dammar ?
all pics are after treatment , except last 3 ones - sent to me from seller , so prior to procedure ...... months ago
if you're puzzled - here is a link for SigJenny sig gene proggie : http://www.natch.co.uk/downloads/SigJenny/SigJenny.html
9 Comments
Zvu
pics pics pics :)
Zvu
droooool :drool:
:D
Beli_Ninja
A cemu sluzi etil-alkohol, lepak za misove i vazelin?
Zen Mod
evidentno si samo gledao slike
:rofl:
Beli_Ninja
Pa naravno, to mi je najinteresantnije. Ako je odgovor u tekstu onda se bacam na citanje. Pravo da ti kazem tek sam sinoc primetio ovaj blog sasvim slucajno.
Zen Mod
"ako je odgovor u tekstu........."
:buehehe:
Beli_Ninja
Srecna i tebi Nova godina nek se ti nama lepo zabavljas.....
