guglajući u potrazi za datasheet za siemens e88cc nalatim na ovo
ftp://ftp.aopen.com/...e/tube-ol-e.pdf
da ne bude zaludno guglanje možda nekoga zaintresuje
6 odgovor(a) na ovu temu
#1
Odgovor 27 November 2011 - 19:11
Strah da samo budem i ništa više
#2
Odgovor 27 November 2011 - 19:13
bilo davno
zaludan pop i jarice krsti , narocito kad moze da proda
da prostis - ko sladoled u vuruni
#3
Odgovor 27 November 2011 - 19:22
Ту плочу нећеш нигде наћи лампе да.
#4
Odgovor 27 November 2011 - 19:24
Cooler Master je spuckao spravicu sa lampom za PC. Musketeer 3 beše, eno se još uvek čeka da dođe dan da se odlučim da pregrejem računar pa da tog dana čudeslo zabodem umesto rezervnog dvd čitača... mmmdaaa... još jedna tema u kojoj ni pre nego sam nalupetao nisam imao ništa pametno da dodam...
#5
Odgovor 27 November 2011 - 19:35
stein, za 27 November 2011 - 19:24, kaže:
Citat
Sure it might be a novel idea, and an easy way to get a front audio port, but what did you guys really expect - that a $50 audio "enhancer" could turn terrible, bottom of the barrel audio ICs around, and pump theater quality surround sound out of any speakers. Does the product do what it says it can - that being, to warm up, and humanize the audio - yes. Is it going to have the same effect as splurging on a real soundcard, and a decent amplifier? Hell no. With the kinks worked out, this is a good idea for users searching for a forward audio port, but otherwise, it just seems to be more trouble than it's worth. At least it looks damn good, though.
No use permitting some prophet of doom to wipe every smile away. Come hear the music play.
#6
Odgovor 27 November 2011 - 22:27
niksi pc sat je daleko bolja stvar u kompu. ničemu ne služi, lepo svetli. broji i ne folira.
#7
Odgovor 28 November 2011 - 14:08
Slične Teme
Izbor komponenti |
Zvucnici | scope |
P: Kit komplet zvučnici |
Oglasi | stein |
Dijafragma kompresionog... |
Zvucnici | milovan1963 |
P: Sto za kompjuter |
Oglasi | Leonardo |
Cudno pucketanje sa kompa |
Digital | Dmeister |
0 Korisnik (a) čita ovu temu
Pristupi
Registruj se
Nazad na vrh
