Pozz.svima !Na prodaju tuner Sansui TU-719 sa rack drzacima,koji su skinuti trenutno,i ne vide se na slikama.Stanje:front besprekoran,bez ijedne ogrebotine,na poklopcu sa gornje strane su vidljivi neki tragovi koriscenja,ali bez oranja,udubljenja i sl.,digitalna skala ne radi,prema jednom majstoru koji je to pogledao,to je pisi kuci propalo,osvetljenje skale zamenjeno sa LED opcijom,ali je to slabo ispalo,nove sijalice narucene i prilikom kupovine kupac ce ih dobiti.sve ostalo ispravnoUzimajuci u obzir trenutno stanje,pocetna cena 220 eura,moguca dostava prema dogovoru do NS-BG-a,prema zelji mogu poslati i slike vece rezolucije..Sve ostalo na PMThanx
  • Odgovora 4
popravljeno,u prilog ide 1 komad rezervne sijalice,sa rack drzacima,par informacija (sa fm tuner info sajta):
Sansui TU-719 (1979, front, back, inside) search eBayThe TU-719 has 4 FM and 2 AM gangs, and 4 ceramic filters, arranged in a different configuration on the circuit board than the TU-717's filters (despite the similar front panels, the TU-719's circuitry is quite different from the TU-717's). The TU-719 has an analog tuning capacitor, with a tuning knob and analog dial scale like the TU-717, but has a digital frequency readout where the 717 has a signal strength meter (it's a vacuum flourescent display, which resembles LEDs). The 719 uses fairly narrow stock ceramic filters and is more selective than an unmodified 717, but some may find the 719's overzealous crystal lock circuitry (like the TU-919's, as described below) an annoyance rather than a convenience. When modified with narrower filters, the TU-719's selectivity only improves slightly, and a DXer or anyone else who changes stations frequently will probably prefer a modified TU-717 since the 717 doesn't have the annoying crystal lock. The TU-719 is somewhat scarce and can sell for anywhere from $150-300 on eBay, with a high of $399 in 1/05. The higher priced 719s usually have rack mount handles. [EF]
  • 1 month later...
Guest
