Da li moze LME49720 Dual Op-amp umesto 21140 u marantz63
Da li moze da se ubaci ovaj OP u cd marantz63 umesto njegovih 21140
■ Power Supply Voltage Range ±2.5V to ±17V
■ THD+N (AV = 1, VOUT = 3VRMS, fIN = 1kHz)RL = 2kΩ 0.00003% (typ)RL = 600Ω 0.00003%
■ Input Noise Density 2.5nV/√ Hz
■ Slew Rate ±20V/μ s
■ Gain Bandwidth Product 55MHz
■ Open Loop Gain (RL = 600Ω ) 140dB
■ Input Bias Current 7nA
■ Input Offset Voltage 0.05mV
■ DC Gain Linearity Error 0.000009%
Features:
■ Easily drives 600Ω loads
■ Optimized for superior audio signal fidelity
■ Output short circuit protection
■ PSRR and CMRR exceed 120dB
Applications:
■ Ultra high quality audio amplification
■ High fidelity preamplifiers
■ High fidelity multimedia
■ State of the art phono pre amps
■ High performance professional audio
■ High fidelity equalization and crossover networks
■ High performance line drivers
■ High performance line receivers
■ High fidelity active filters
  • Odgovora 1
Popularni dani
Popularni dani
