zarko1803 Napisano Mart 9, 2012 Share #1 Napisano Mart 9, 2012 Da li moze da se ubaci ovaj OP u cd marantz63 umesto njegovih 21140 ■ Power Supply Voltage Range ±2.5V to ±17V ■ THD+N (AV = 1, VOUT = 3VRMS, fIN = 1kHz)RL = 2kΩ 0.00003% (typ)RL = 600Ω 0.00003% ■ Input Noise Density 2.5nV/√ Hz ■ Slew Rate ±20V/μ s ■ Gain Bandwidth Product 55MHz ■ Open Loop Gain (RL = 600Ω ) 140dB ■ Input Bias Current 7nA ■ Input Offset Voltage 0.05mV ■ DC Gain Linearity Error 0.000009% Features: ■ Easily drives 600Ω loads ■ Optimized for superior audio signal fidelity ■ Output short circuit protection ■ PSRR and CMRR exceed 120dB Applications: ■ Ultra high quality audio amplification ■ High fidelity preamplifiers ■ High fidelity multimedia ■ State of the art phono pre amps ■ High performance professional audio ■ High fidelity equalization and crossover networks ■ High performance line drivers ■ High performance line receivers ■ High fidelity active filters Link to comment Podeli na ovim sajtovima More sharing options...
zbotic Napisano Mart 9, 2012 Share #2 Napisano Mart 9, 2012 Može. Odličan izbor. Link to comment Podeli na ovim sajtovima More sharing options...
