Boki Napisano Mart 12, 2010 #1 Napisano Mart 12, 2010 Na ovom sajtu imate kvalitetno ripovane albume:http://www.avaxhome.ws/music/format_bitrate/extreme_hqObično za svaki navedu pod 'Technical info" sa kojom opremom su ripovali, da li je 24-bit/96kHz itd.
Boki Napisano Mart 12, 2010 Autor #2 Napisano Mart 12, 2010 The advantage of 24/96 files can best be illustrated by comparing them to Compact Discs. CDs consist of two channels of 16-bit PCM audio sampled 44,100 times per second. A 24/96 recording can contain up to 24-bit PCM audio sampled 96,000 times per second.This may sound a little technical, so here is an analogy: If you look closely at a photo in a newspaper, you will see that the image is actually made up of small dots.The more dots per square inch, the higher the clarity of the photo.The same is true for music in 96/24 when compared to standard CD audio. This represents a substantial increase in the resolution and bandwidth of the recording. The depth and texture of the music will be more apparent. Heightened dynamic contrast will add excitement to your listening experience. Because the sampling rate has been more than doubled to 96 kHz, you will experience effortless high-frequency extension and purity. You really can hear the difference!
stefaca Napisano Mart 12, 2010 #4 Napisano Mart 12, 2010 http://rutracker.org/forum/index.phpzilioni muzike i koncerata svih zivih formata. kao registrovan user mozes skinuti samo 5GB ali zato ratiomaster pa lazes da serujes u ogromnim kolicinama i skidas koliko ti dusa zeli
