measurement standards: noise level / dynamic range / signal to noise ratio
Здраво свима
Извините
Не знам технички српски, па пишем на енглеском
Српски учим тек пола године
Where can I find measurement specifications, does anyone know links to current/modern documentation?
For example, is it possible to measure the noise level of a sound card with a gain ratio of 1 to 1? (assume the input is ideal and measure only the output)
How is dynamic range measured? i.e. 32 bit integer pcm dr=192 dB , but OVP can add analog clipping at lower amplitude, then i can find max volume without clipping and dr=max vol - noice level and signal to noise ratio = max volume/noice level ?
  • Odgovora 2
Popularni dani
ARTA, REW and plenty of similar measuring programs
ggle for "sound card measuring software" or something as that
https://www.google.com/search?hl=en&as_q=sound+card+measuring+software&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=&as_occt=any&as_filetype=&tbs=
each of these programs is most likely having on-line help/manual page
I'm searching how to measure according to international standard, i'm writing my own software for measuring and REW measured not exactly DR, rmaa - everything is lying, didn't watch ARTA yet
