dunavko Napisano Decembar 22, 2020 Share #1 Napisano Decembar 22, 2020 Ts-585 Audio Output Level Meter Ispravan,dobro ocuvan u metalnoj kutiji Karakteristike su za model C.Ima services manual na NETU. cena: 7000 dinarjev Output Watt Meter Part Numers: TS-585 C/U, 6625-83450 NSN: 6625-00-649-4646 Circuit Current for Which Designed: AC Overall Length: 5.500 inches nominal Overall Height: 8.250 inches nominal Overall Width: 11.000 inches nominal Indicator Type: Dial W/pointer Installation Design: Bench Dial Scale Marking Color: Red single indicator single range Accuracy in Percent: -5.0 to 5.0 at full scale single indicator single range Background Color: White single indicator single range Measurement Range: +0.0 to 37.0 decibels single indicator 1ST range Measurement Range: +0.0 to 5.0 watts single indicator 2ND range Scale Selection Method: Switch Features Provided: Portable Circuit Attachment Method and Quantity: 2 phone jack Reference Data and Literature: 33A1-7-23-1 Style Designator: Rectangular or square Link to comment Podeli na ovim sajtovima More sharing options...
dunavko Napisano Decembar 29, 2020 Autor Share #2 Napisano Decembar 29, 2020 e ovaj watmetar ako nije potreban onda ... Link to comment Podeli na ovim sajtovima More sharing options...
