Pretraži DiyAudio.rs
Showing results for tags 'wireless charger'.
  • Pretraga po Tagovima
    Tagove odvojite zapetama
  • Pretraga po Autoru
Tip Sadržaja
Forumi
    • Project gallery/WIKI
    • Galerija sistema
    • Fresh Gadgets Galery
    • Vintage audio museum
    • Solid State
    • Tubes
    • Digital
  • Izvori / Sources
    • Analogue
    • Digital
    • Izvori napajanja
  • Zvučnici / Loudspeakers
    • Zvučnici
  • HI-FI Audio
    • Hi-Fi audio
    • Hi-End Audio
    • Hi-Fi scena
    • Muzika , Film i Fotografija
    • Oglasi
    • Grupne nabavke
    • Data and tips
    • TEORIJA I TRIKOVI
    • Cases/Boxes for gadgets
    • Gde nabaviti ?
  • The Moving Image
    • The Moving Image
  • Sve Drugo / Everything Else
    • Druženje / Meets
    • IT
    • Moto
  • Aeroklub's Aeroklub
Blogovi
  • Daudio
  • Merenja za neuke :)
  • Stein's Blog
  • Zen Mod's Blog
  • Quattor's Blog
  • Zvuchniak's Blog
  • Mrs.Magura's Blog
  • Mrs.Magura's Blog
  • Beli_Ninja's Blog
  • Данетов Блог
  • Maljkovic's Blog
  • Misha's Blog
  • ManicP's blog
  • Woland's Blog
  • Lampasko pojacalo 2xEL504
  • Beaver's Blog
  • nemacka
  • Audio sistem za stan
  • Electrocompaniet AW100
  • sp300b
  • Вукашин
  • Kakao napraviti pojacalo.
Prikaži rezulte iz
Prikaži rezultate koji sadrže
Po datumu
  • Start
    End
Poslednje izmene
  • Start
    End
Filtriraj po broju ...
Učlanjen
  • Start
    End
Grupa
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Lokacija:
Interesovanja:
  1. How to make your own DIY book charger 1. First, you should buy a small wireless charger. Look for one that is small, slim, and doesn’t raise the temperature too much while loading. Obviously, if the temperature goes too hot, it will burn the book. I bought this one from Amazon, you can search the key word on Amazon: Soopus-X wireless charger 15W for this item. 2. Next, find an old book you are willing to cut up. Make sure the cover not too thick because the thicker the cover is, the weaker the signal will be. 3. Then, you should use a pencil to mark the shape and position of the charger on the page. 4. Next, use a sharp knife to cut a hole in the book pages where the charger will go. 5. After that, you should also cut a hole for where the cable exits the book. 6. Then, hide the wireless charger inside the book and use tape to stick it. 7. Please note that, if you are using the same wireless charger I am using, you should get a QC 3.0 adapter or it won’t charge well. 8. This small wireless charger is too small to locate, especially when it is hidden under the book, so, you should find some thing to help to locate it. 9. If your phone do not have wireless charging feature, you should buy a receiver. After you finish, you will see the art just like here. Finally, It works. Amazon key word in case you need : Soopus-X wireless charger 15W The video on how I did it: link:
