Pretraži DiyAudio.rs
Showing results for tags 'iron pumpkin'.
  • Pretraga po Tagovima
    Tagove odvojite zapetama
  • Pretraga po Autoru
Tip Sadržaja
Forumi
    • Project gallery/WIKI
    • Galerija sistema
    • Fresh Gadgets Galery
    • Vintage audio museum
    • Solid State
    • Tubes
    • Digital
  • Izvori / Sources
    • Analogue
    • Digital
    • Izvori napajanja
  • Zvučnici / Loudspeakers
    • Zvučnici
  • HI-FI Audio
    • Hi-Fi audio
    • Hi-End Audio
    • Hi-Fi scena
    • Muzika , Film i Fotografija
    • Oglasi
    • Grupne nabavke
    • Data and tips
    • TEORIJA I TRIKOVI
    • Cases/Boxes for gadgets
    • Gde nabaviti ?
  • The Moving Image
    • The Moving Image
  • Sve Drugo / Everything Else
    • Druženje / Meets
    • IT
    • Moto
  • Aeroklub's Aeroklub
Blogovi
  • Daudio
  • Merenja za neuke :)
  • Stein's Blog
  • Zen Mod's Blog
  • Quattor's Blog
  • Zvuchniak's Blog
  • Mrs.Magura's Blog
  • Mrs.Magura's Blog
  • Beli_Ninja's Blog
  • Данетов Блог
  • Maljkovic's Blog
  • Misha's Blog
  • ManicP's blog
  • Woland's Blog
  • Lampasko pojacalo 2xEL504
  • Beaver's Blog
  • nemacka
  • Audio sistem za stan
  • Electrocompaniet AW100
  • sp300b
  • Вукашин
  • Kakao napraviti pojacalo.
Prikaži rezulte iz
Prikaži rezultate koji sadrže
Po datumu
  • Start
    End
Poslednje izmene
  • Start
    End
Filtriraj po broju ...
Učlanjen
  • Start
    End
Grupa
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Lokacija:
Interesovanja:
  1. Iron Pumpkin preamplifier(s) kits Mrzi me da ponovo pisem (na srpskom) pa samo paste sa Big DiyA: cene za tuzemstvo/Otadžbinu/lokal - bez shipping i paypal troskova i jos 10% dole Well , everything explained and shown in technical thread : http://www.diyaudio.rs/topic/8681-iron-pumpkins/ on sale are several options : 1. Iron Pumpkin SE (yup , that one being for RCA inputs/outputs) ,consisting of : -Iron Turtle SE AVC , as assembled and tested unit (two irons on one common pcb ), rotary switch ,50cm flat cable finished, necessary stand-offs -two pcs of Iron Pumpkin SE mono pcbs (selector, shunt regs , buffer -all that on one pcb) , with all small SMD JFets presoldered , all BC bjt critters , voltage references , BD bjts for reg CCS ,all relays, Philips MKC 1uF caps , selector Lorlin switch with two finished flat cables, all multiturn trimpots , necessary 1-pin sockets for optional Borbely WCF buffer iteration, u22 cap for WCF price - measly 550E , plus 30E for Paypal , P&P expenses 2. Iron Pumpkin (Bal) (yup , that one being for XLR inputs/outputs , possible combination with RCAs, read threads for that) ; that one consisting of : -Iron Turtle (Bal) AVC , as assembled and tested unit (one iron on one pcb but two pcbs stacked having same footprint as previous one) , rotary switch,50cm flat cable finished, necessary stand-offs -two pcs of Iron Pumpkin (Bal) mono pcbs (selector, shunt regs , buffer -all that on one pcb) , with small SMD JFets presoldered , all BC bjt critters , voltage references , BD bjts for reg CCS ,all relays, Philips MKC 1uF caps , selector Lorlin switch with two finished flat cables, all multiturn trimpots , necessary 1-pin sockets for optional Borbely WCF buffer iteration, u22 cap for WCF price - measly 650E , plus 30E for Paypal , P&P expenses 3.Iron Turtle SE AVC (so no electronics), as assembled and tested unit (two irons on one common pcb) , rotary switch ,50cm flat cable finished, necessary stand-offs price - measly 450E , plus 30E for Paypal , P&P expenses 4.Iron Turtle (Bal) AVC (so no electronics) , as assembled and tested unit (one iron on one pcb but two pcbs stacked having same footprint as previous one) , rotary switch,50cm flat cable finished, necessary stand-offs price - measly 550E , plus 30E for Paypal , P&P expenses 5. Iron Pumpkin SE electronics ( so no AVC in package ) (yup , that one being for RCA inputs/outputs) ; that one consisting of : -two pcs of Iron Pumpkin SE mono pcbs (selector, shunt regs , buffer -all that on one pcb) , with all small SMD JFets presoldered , all BC bjt critters , voltage references , BD bjts for reg CCS ,all relays, Philips MKC 1uF caps , selector Lorlin switch with two finished flat cables, all multiturn trimpots , necessary 1-pin sockets for optional Borbely WCF buffer iteration, u22 cap for WCF price - measly 130E , plus 20E for Paypal , P&P expenses 6. Iron Pumpkin (Bal) electronics ( so no AVC in package)(yup , that one being for XLR inputs/outputs , possible combination with RCAs, read thread for that) ; that one consisting of : -two pcs of Iron Pumpkin (Bal) mono pcbs (selector, shunt regs , buffer -all that on one pcb) , with small SMD JFets presoldered , all BC bjt critters , voltage references , BD bjts for reg CCS ,all relays, Philips MKC 1uF caps , selector Lorlin switch with two finished flat cables, all multiturn trimpots , necessary 1-pin sockets for optional Borbely WCF buffer iteration, u22 cap for WCF price - measly 160E , plus 20E for Paypal , P&P expenses for all technical questions , visit linked thread for other questions - ask here or in PM considering prices from other vendors of AVC thingies , I believe this is pretty good bang for the buck shipping time from 1 to 4 weeks ......... sometimes things need to flow from Germany or China ...... and yes case/chassis needed : regular width , minimum 3HE
