Pretraži DiyAudio.rs
Showing results for tags 'fender stratocaster screening'.
  • Pretraga po Tagovima
    Tagove odvojite zapetama
  • Pretraga po Autoru
Tip Sadržaja
Forumi
    • Project gallery/WIKI
    • Galerija sistema
    • Fresh Gadgets Galery
    • Vintage audio museum
    • Solid State
    • Tubes
    • Digital
  • Izvori / Sources
    • Analogue
    • Digital
    • Izvori napajanja
  • Zvučnici / Loudspeakers
    • Zvučnici
  • HI-FI Audio
    • Hi-Fi audio
    • Hi-End Audio
    • Hi-Fi scena
    • Muzika , Film i Fotografija
    • Oglasi
    • Grupne nabavke
    • Data and tips
    • TEORIJA I TRIKOVI
    • Cases/Boxes for gadgets
    • Gde nabaviti ?
  • The Moving Image
    • The Moving Image
  • Sve Drugo / Everything Else
    • Druženje / Meets
    • IT
    • Moto
  • Aeroklub's Aeroklub
Blogovi
  • Daudio
  • Merenja za neuke :)
  • Stein's Blog
  • Zen Mod's Blog
  • Quattor's Blog
  • Zvuchniak's Blog
  • Mrs.Magura's Blog
  • Mrs.Magura's Blog
  • Beli_Ninja's Blog
  • Данетов Блог
  • Maljkovic's Blog
  • Misha's Blog
  • ManicP's blog
  • Woland's Blog
  • Lampasko pojacalo 2xEL504
  • Beaver's Blog
  • nemacka
  • Audio sistem za stan
  • Electrocompaniet AW100
  • sp300b
  • Вукашин
  • Kakao napraviti pojacalo.
Prikaži rezulte iz
Prikaži rezultate koji sadrže
Po datumu
  • Start
    End
Poslednje izmene
  • Start
    End
Filtriraj po broju ...
Učlanjen
  • Start
    End
Grupa
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Lokacija:
Interesovanja:
  1. Fender Stratocaster tweaks , for hum reducing - 0,3mm Cu foil , cut to strips and fields , glued with neoprene glue to back of mask , entire body cavity - all Cu planes strategically connected with soldering and grounded to CT Ground - back of volume pot - entire wiring changed to screened two wire cable , where screen is connected as shield strictly - on upstream signal side - pot shafts lightly oiled Woland's Kidoe will enjoy , I'm sure .............. - ignore predominant red color on pics - it's from red velvet and my red plastic terrace roof
