  • unosa
    87
  • komentara
    338
  • pregledâ
    130020
razmagnetisanje drivera - ukratko i slatko
odavde : http://www.audioheri...ll=1#post110522
Quote
Here's the Scoop
Ferrite magnets do not demagnitize with time or drive. They are affected by temperature but that is reversible. They will return to normal when they return to room temperature. Ferrite is basically a lousy magnet material for speakers but it is cheap and readily available. JBL has done a ton of things within the magnetic circuit to make the material behave in a more stable manner. At 100 degrees F, a Ferrite motor will be down about 1.5 dB in level which means the midband of the woofer will be lower by that much and there will be increased output around the system resonance. The TS parameters will be completely different - as though the BL was reduced by about 18%.Alnico magnets, by their nature are easy to demagnitize with drive. They will not change with time and their dependence on temperature is really small - maybe 1% at 100 deg.F. Alnico stability and resistance to back EMF is really good. This is why they make the best sounding magnetic structures. Unfortunatelly, given a big enough pulse of magnetic energy, they will demagnitize by up to 3 dB. The sensitivity to demagging is dependent on the specifics of the magnetic circuit and the length of the coil providing the field. Underhung woofers (LE15 and such) midranges, tweeters and compression drivers do not have sufficient back EMF fields to push the operating point of the structure below the knee. They are essentially stable regardless of input signal. The short gap-long coil speakers are the ones that have a problem. A 2235 can take a hit of up to 3 dB if a big enough hit of current takes place. 1.5 dB to 2 dB is more common. The effect does not get better or worse with time, it solely depends on how much current is driven through the coil. The more current, the more field. Once the field is bigger than a certain number, some amount of demagnitizing occurs. It is perminent (until externally recharged) and will only increase if a larger sustained current hit occurs. Therefore, if you have a qualifying alnico woofer and you have played it loudly you have some damagging. You can have the unit recharged and it will be fine until you play it again. Exceed the critical level and it will start happening. If you never do, it won't ever demag. Most of these designs trace back to the 50's and 60's where 15 - 30 watt tube amps were the rule. They didn't have the current capability to hurt anything. With the advent of big solid state amps, the current levels went up and the problems started to surface.Most of the qualifying 4" motors will loose 1 - 1.5 dB unless they are pummeled. Some of the older 3" with really short magnets, like the 2213A and 123A will typically be around 3 dB down. They go really easily. The old decade woofers (116A and 127A) only had to see an amplifier in the room and they got really nervous. FYI, the new 1500Al used in the S9800 can take continued pulses of 5000 watts and loose no more than 1%. The test can only be done a few times before the coil is destroyed, but the magnetic assembly is totally stable.
4 Comments
dusan
moj kolega koji je majstor u popravci zvučnika ima mašinu za razmagnetisanje i namagnetisanje zvućnika.Takodje upotrebljava za osveživanje starih alnico magneta..
Zen Mod
zahvaljujem
gabariti koje moze da savlada sa masinom ?
neki kontakt ?
mozda i da postujes taj info u "zvucnici" subforum
dusan
gabariti nisu problem jer je veoma velika,koristi trofaznu struju,i kako znam jedina je daleko naokolo.samo je mali problem udaljenosti jer je majstor iz ljubljane.
dodajem i broj 0038641699747,sandi.
Zen Mod
zahvaljujem :clapping:
pretpostavljam da ce neko biti zainteresovan ........ ko ima Altec kompresione drivere za recharging :drinks:
  • Podeli ovaj blog
    Podeli na Facebook-u ili X-u :
