  • unosa
    87
  • komentara
    338
  • pregledâ
    126208
Izmena u ovom blogu
Douglas Adams and FiFi
My Irish Dodo (brianco @ Diyaudio) sent me enormous sized pdfs ......... it simply must be on-line ....... enjoy !
Zen Mod
Zen Mod
Be's Millenium 6000 repair/WBT termination
few day's work ; reason for operation was - broken ends , due to too much manipulation ( they aren't exactly made flexible .... while still fragile ) intention was to dismantle them , without ruining end stickers .......... ya can call me enthusiast however , thin foils are better ........ to my ears btw - main stickers ( at fork ends ) are having arrows , as that cables are "directioned" I couldn't see any fact for that , in their construction
Zen Mod
Zen Mod
Taming da Beast - Stratocaster
Fender Stratocaster tweaks , for hum reducing - 0,3mm Cu foil , cut to strips and fields , glued with neoprene glue to back of mask , entire body cavity - all Cu planes strategically connected with soldering and grounded to CT Ground - back of volume pot - entire wiring changed to screened two wire cable , where screen is connected as shield strictly - on upstream signal side - pot shafts lightly oiled Woland's Kidoe will enjoy , I'm sure .............. - ignore pre
Zen Mod
Zen Mod
Tannoy OB fun ...... brute force approach
K3809 as main driver , K3833(K3836) as bass helper K3809 are mine , while K3833(K3836) (stars of previous blog entries ) are prepared for SuperFi's Westminster project just having fun with some old OB "wood" , gift from Chakija ( he's not feeling young enough to continue playing with them ....... ) to be continued ...... these days I hope to have some time to mount crude xover , and put them in living room disclaimer - I'm really not expecting real bass ....... that's max wi
Zen Mod
Zen Mod
Tannoy K3836 - painting da throat (completion of two previous blog entries)
remove compression driver , sand horn throat, degrease it , cover cone with paper inlets , spray-paint da throat, wait , Dammar everything ( as Gusztav made the button ) , put compression driver back that's it - now K3833 is same as K3836 , excluding two funny golden rings ( to be precise - K3833 having gray basket and two golden rings , while K3836 having black basket and no silly golden rings )...... which will be invisible in WM , anyway . ...... A day later - measured Fs for both b
Zen Mod
Zen Mod
Tannoy 3836 - cleaning da gap ......back in action ;)
I'm lazy to comment each picture ; cleaned , horn throat sanded , degreased , painted ; spider area on basket cleaned from glue residue prior to re-gluing it , VC is alligned with shims made of redundant photo ( didn't had usually used plastic foils near by) spare mesh dust cap placed just for fun ...... it will not be used I intend to redo other driver's horn throat in black , to make them same-looking so - pretty much same work as....or even less than complete recone .
Zen Mod
Zen Mod
Pair of non-matched Tanns - one 3833 (mint) and one 3836 ( supposedly needing recone ) , tnx to enormous and kind help of Ninja - obtained from outer space for my kiddoe - SuperFi . As confirmed on net , difference between 3833 and 3836 is just here and there in color of some details ( golden ring around surround on one of them , while on other one, that ring is black) . After some examination , measurements of all coils Rdc , I decided to make most direct and most benign steps , to de
Zen Mod
Zen Mod
Babelfish F6 and F6 Bal iterations
concept sims ; biasing nets not shown in detail , as they're shown in hand drawn schematic 4 coils repeater (SE and Bal versions) , 5 coils repeater Bal. ,6 coils repeater Bal.
Zen Mod
Zen Mod
CCS Donut amp
15W/8R +30Vdc/-10Vdc Iq 4A 160W dissipation C6 on schematic is 10uF ; 10k is typo , obviously
Zen Mod
Zen Mod
Scent of ole times ...
those were days ....... Hans Dietze's ( Harry F. Olson's colleague) speech , taken from http://oswaldsmillaudio.com/underground/2006.html   aiff file converted to mp3 , download it and listen fun and informative   luckily , those old guys didn't had all the fun , something is left for us   some info about H.F. Olson : http://en.wikipedia.org/wiki/Harry_F._Olson     Herr H. DIetze :         Han
Zen Mod
Zen Mod
My friend ......
who is living in far Casablanca ......     http://www.youtube.com/channel/UCZvAXv-hdRNTsZE1qZPcXvA/videos
Zen Mod
Zen Mod
Tannoy K3809 - hardened cloth surround issue - solved
I'm lazy , so there are excerpts from my correspondence on Tannoy Yahoo group; all quotes - Mighty ZM   I'm putting this here as future reference for some other desperate Tanner ; I must admit ( or I'm just boasting ) - I'm always having serius backup for all things speakers - from Aleksandar RAAL ....... even if I'm always stubborn and I'm bugging him only post hoc ..... to be sure that I didn't blew something           of course - "Danish guy " wasn'
Zen Mod
Zen Mod
