Welcome to diyAudio.rs
Okibokis
Magnum mc 250
45 posts in this topic
Setting bias I have learnt for FET amps is a bit hit or miss.
I load the amp with the current set to zero on the pre-set.
Then a 10KHz signal is plug in so the the 8 Ohm load RESISTOR has just 2 Volts Pk-Pk
You can then clearly see the Cross Over distortion on a scope.
Adjust the pre-set with care until the distortion is gone, keep a careful monitor of the heat sink temperature and it is best a a ambient of 25C
The Amp will sound amazing and run slightly warm and low levels.
I hope this helps?
Best Col
Zflazar and bnb like this
Share this post
Link to post
Share on other sites
We have done the same thing in the past. Magnum and now it plays nice and smooth. Thanks for the suggestion and if you can get a little more details about this enhancer with which you were in the picture, I would be grateful.
Share this post
Link to post
Kasno se javio konstruktor.
Nije me pre interesovalo, ali sam sad sve iscitao, i  proguglao, tako da je ovo po svemu sudeci zavrsni rezultat; evo slike sa komsijskog fifi foruma. Opis u oglasu je, pa da tako kazemo  - neodoljiv!
Okibokis likes this
Share this post
Link to post
Sad mi dodje zao,ali idemo dalje.Zar jos postoje slike sa KP?
Bose likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
