Spachek Napisano Decembar 11, 2015 #1 Napisano Decembar 11, 2015 Zvucna karta o kojoj ne treba mnogo govoriti, prvi i jedini vlasnik, fabricko stanje, nista menjano, cackano i sl. Garancija istekla 25.10.2015. Dolazi u originalnoj ambalazi sa svom pripadajucom dokumentacijom i pratecim konektorima. Cena za clanove 115 evra. Kontakt na PP. https://www.asus.com/Essence-Hi-Fi-Audio/Xonar_Essence_STX/overview/ Audio Interface PCI Express Audio Performance Output Signal-to-Noise Ratio (A-Weighted) (Front-out) : 124 dB Output Signal-to-Noise Ratio (A-Weighted) (Headphone-out) : 117 dB Input Signal-to-Noise Ratio (A-Weighted) : 118 dB Output THD+N at 1kHz (Front-out) : >0.0003 %(-110 dB) Output THD+N at 1kHz (Headphone-out) : >0.001 %(-100 dB) Frequency Response (-3dB, 16bit/44.1KHz input) : 10 Hz to 90 KHz Output/Input Full-Scale Voltage : Line output (RCA, 3.5) : 2 Vrms (5.65 Vp-p) Chipset Audio Processor : ASUS AV100 High-Definition Sound Processor (Max. 192KHz/24bit) Digital-to-analog Converter(DAC) TI Bur-Brown PCM1792A Sample Rate and Resolution Analog Playback Sample Rate and Resolution : 44.1K/48K/96K/192KHz @ 16bit/24bit Analog Recording Sample Rate and Resolution : 44.1K/48K/96K/192KHz @ 16bit/24bit S/PDIF Digital Output : 44.1K/48K/96K/192KHz @ 16bit/24bit ASIO Driver Support : 44.1K/48K/96K/192KHz @ 16bit/24bit Connectivity Analog Output 1 x 6.3 mm jack (1/4") Headphone out 2 x RCA (Un-Balanced) Analog Input 1 x 6.3 mm jack (1/4") (Line-in/ Mic-in combo) Digital 1 x S/PDIF out (1 x Optical / Coaxial combo) 1 x Front-Panel Header 1 x Aux in (4-pin header) Special Features Dolby® Technologies : Dolby® Digital Live/Dolby® Headphone /Dolby® Virtual Speaker /Dolby® Pro-Logic II Karaoke Functions FlexBass™ GX 2.5 Game Audio Engine VocalFX™ Operating System Windows® 10 Windows® 8.1 Windows® 8 Windows® 7 Windows® XP Accessories S/PDIF adapter x 1 3.5mm-to-RCA cable x 1 6.3mm-to-3.5mm adapter x 0 Quick start guide x 1 Driver CD x 0
