P: Exadevices exaU2I USB to I2S konverter
Prodajem uredjaj iz naslova. Jedan od boljih u svojoj klasi. Posto sam odustao od izrade DAC uredjaja to mi je visak.
Originalni projekat :
http://www.diyaudio.com/forums/exadevices/183374-exau2i-multi-channel-asynchronous-usb-i2s-interface.html
• Sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8• Resolution (bits): 16, 24, 32• 8, 4 or 2 channels for sampling rates up to 192 kHz• 4 or 2 channels for 352.8 kHz• Galvanic isolation between the USB ground and the I2S outputs.• Two quartz oscillators for the 44.1 kHz and 48 kHz sampling rate groups• FPGA implementation• 256 kB FIFO buffer to support asynchronous operation• Two analogue voltage regulators with filters• Sample rate LED indicators• USB power LED indicator• Buffer level LED indicator• Four I2S data outputs (8 channels) powered by the DAC power supply (3.3V or 5V)• USB 2.0 interface, Mini USB connector• Proprietary bit-perfect ASIO driver completely independent from the Windows sound system; No software volume control or mixing.• ASIO driver implements automatic sampling rate switching; no re-sampling• Works on Windows XP, Windows Vista and Windows 7.• Tested with Foobar and J.River Media Center• Project homepage – http://www.exaDevices.com
Kostalo je 430$ u USA. Cena je 180Eur.
  • Odgovora 2
Popularni dani
Guest
