El. Cevi, Kondezatori, Transformatori...
Elektronske Cevi: 1. 6N1P-EV - SSSR - vise komada - 450 Din/Kom 2. GU-50 - SSSR - vise komada - 500 Din/Kom 3. 6C4P - SSSR - vise komada - 200 Din/Kom 4. 6P1P - SSSR - vise komada - 400 Din/Kom 6. ECC82 - EI Nis - 3 kom. - 500 Din/Kom 7. PCL86 - EI Nis - 4 kom. - 400 Din/Kom 8. PCL82 - EI Nis - 3 kom. - 400 Din/Kom 9. 1P24B - SSSR - vise komada - 250 Din/Kom10. 6N1P - SSSR - vise komada - 200 Din/Kom11. 3A4 - USA - vise komada - 300 Din/Kom12. 3V4 - USA - vise komada - 300 Din/Kom13. 3B4 - USA - vise komada - 300 Din/Kom14. 3Q4 - USA - vise komada - 300 Din/Kom15. 3S4 - USA - vise komada -300 Din/Kom16. 85A2 - Philips - 1 kom. - 500 Din/Kom17. 1R5 - Philips - 1 kom. - 300 Din/Kom18. 1L4 - USA - vise komada - 300 Din/Kom19. 1Z29B - SSSR - vise komada - 200 Din/Kom20. 6Z5B-V - SSSR - vise komada - 200 Din/Kom21. 6Z1B-V - SSSR - vise komada - 200 Din/Kom22. ECL86 - EI Nis - 4 kom. - 500 Din/Kom23. NOVAL (9 pinova) i MINIATUR (7 pinova) podnozja za lampe sa zastitnim poklopcima - 200 Din/Kom24. Podnozja za GU-50 - 500 Din/Kom25. OCTAL podnozja - 200 Din/Kom Kondezatori: 1. 1uF/400V - PIO (Paper In Oil) - vise komada - 50 Din/Kom 2. 2uF/400V - PIO (Paper In Oil) - 10 kom. - 100 Din/Kom 3. 4uF/300V - PIO (Paper In Oil) - vise komada - 100 Din/Kom 4. 4uF/400V - PIO (Paper In Oil) - vise komada - 150 Din/Kom 5. 10uF/300V - PIO (Paper In Oil) - 6 kom. - 200 Din/Kom 6. 15uF/200V - PIO (Paper In Oil) - 2 kom. - 250 Din/Kom 7. 20uF/160V - PIO (Paper In Oil) - 4 kom. - 300 Din/Kom(Kondezatori nose oznake: MBGO-1, MPHP-,1 OMBG-1, MBGO-2, MBGP-1) 8. 560uF/350V - Sprague ExtraLytic - 2 kom. - 350 Din/Kom 9. 10000uF/ 40V - SIC SAFCO - 2 kom. - 300 Din/Kom10. 470uF/385V - Philips - 1 kom. - 300 Din/Kom11. 4700uF/ 40V - RIFA - 2 kom. - 400 Din/Kom12. 680uF/250V - Philips - 4 kom. - 250 Din/Kom13. 30uF/300V - Ruski Elektroliti - 2 kom. - 350 Din/Kom14. 27nF/630V - MFK 20% - 200 Din/10 Kom.15. 680pF/ 63V - Stiroflex 5% - 800 Din/15 Kom. 16. 470pF/ 63V - Stiroflex 5% - 200 Din/ 5 Kom. 17. 4700pF/ 63V - Stiroflex 5% - 300 Din/ 5 Kom.18. 68uF/ 6V - Tantal Elektroliti - 400 Din/10 Kom. 19. 0,68uF/ 63V - Siemens MKL - 500 Din/10 Kom. 20. 3,3uF/100V - Wima MKS-4 - 500 Din/ 4 Kom. 21. 0,1uF/400V - KBG-M1,M2(20%, 10%)PIO - 400 Din/ 4 Kom. 22. 4700uF/ 35V - Elektroliti NKL - 3 kom. - 200 Din/Kom 23. 2,2uF 250V AC/400V DC - Bennic polipropileni 5% - 2 kom. - 400 Din/Kom24. 0,47uF/250V - Wima polipropileni - 10 kom. - 100 Din/Kom25. 220uF/400V - Nipon - 2 kom. - 700 Din/Kom26. 100uF/400V - Epcos - 2 kom. - 600 Din/Kom27. 100uF/400V - Cornell Dubilier - 2 kom. - 600 Din/Kom28. 47uF/400V - Cornell Dubilier - 2 kom. - 400 Din/Kom29. 100uF/400V - Hitachi - 1 kom. - 400 Din/Kom30. 0,22uF/630V - Iskra KPTU - vise komada - 150 Din/Kom Potenciometri: 1. Alps 10K ohm/LIN - Potenciometar za balance - 4 kom.- 500 Din/Kom 2. Alps 10K ohm/LIN - Potenciometar za balance sa fiksiranjem u srednjem polozaju -2 kom.- 600 Din/Kom Transformatori: 1. Mrezni transformator, toroidni - 160VA, primar 220V, sekundar 2x12,5V - 1400 Din 2. Mrezni Transformator, toroidni - 500VA, primar 220V, sekundar 2x25V precnika 145mm i visine 65mm - 3200 Din 3. Mrezni transformator, C jezgro - 600VA, primar 220V, sekundar 2x36V moze da se poveze da bude 2x16V + 2x20V, tezina oko 12kg - 5300 Din 4. Komplet mreznih transformatora za cevni preamp: 1) primar 220V, sekundar 13V/2A - C jezgro 2) primar 220V, sekundar 120V/500mA, cena za oba 1500 Din.Kontakt: Ivan, 063/156-888-4 (bez SMS-a molim)E-mail: [email protected]
  • Odgovora 14
Neka, neka, bogat oglas, pun materijala, prava DIY-erska prodavnica -ima i za lampiziranje frizidera... ;)BTW Ivane, odakle si - nisi upisao Location, samo country ?I... Dobro dosao na forum! :cheers:
Добродошао  :cheers:.Што бар не стави са КП-а било би лепше:http://www.kupujemprodajem.com/Podnozja-Octal-363176-oglas.htm?filter_id=558http://www.kupujemprodajem.com/Kondezatori-MFK-27nF-630V-20--342671-oglas.htm?filter_id=60942http://www.kupujemprodajem.com/Stiroflex-Kondezatori-680pF-63V-5--342670-oglas.htm?filter_id=60942http://www.kupujemprodajem.com/Wima-3-3uF-100V-342653-oglas.htm?filter_id=60942http://www.kupujemprodajem.com/Kondezatori-KBG-M1-M2-342649-oglas.htm?filter_id=60942http://www.kupujemprodajem.com/Bennic-Polipropileni-336417-oglas.htm?filter_id=60942http://www.kupujemprodajem.com/Elektroliti-336414-oglas.htm?filter_id=60942Има тога још, а ово ти је и бесплатна реклама!
  • 2 months later...
Pozdrav svima ljudi, imam nove cevi u ponudi (sve cevi su NOS, EI Nis): 1. PCL-86 - 500din/kom 2. PCL-84 - 400din/kom 3. PL-36 - 700din/kom. 4. PL84 - 600din/kom. 5. PCF-200 - 300din/kom. 6. PCF-201 - 300din/kom. 7. PCF-801 - 300din/kom. 8. PCF-802 - 300din/kom. 9. PCF-80 - 300din/kom. 10. EF-80 - 300din/kom.11. ECH-84 400din/kom.12. ECH-42 - 400din/kom. (Tungsram)13. PCH-200 - 300din/kom.14. EF-184 - 500din/kom.15. EF-183 - 500din/kom. 16. PY-88 - 400din/kom.17. PC-900 - 350din/kom. 18. ECC-85 - 500din/kom.19. PCC-88 - 450din/kom.20. PCC-88 - 450din/kom. (ruska)
  • 3 nedelje kasnije...
Guest
