khachai44
Sve objavljeno od khachai44
  1. Hi,I'd like to connect RME UCX line out to PA.The mixer is far away so I have to connect to stage box which has XLR inputs that go to Mixer Mic input.RME UCX line out specs:• Output: 6.3 mm TRS jack, servo-balanced• Output impedance: 75 Ohm• Output level switchable Hi Gain, +4 dBu, -10 dBV• Output level at 0 dBFS @ Hi Gain: +19 dBu• Output level at 0 dBFS @ +4 dBu: +13 dBu• Output level at 0 dBFS @ -10 dBV: +2 dBVI am not sure about the PA Mixer specs or even if it has Pad on inputs.I am sending full stereo mix, so don't want any artifacts like tonal shifts or loss of dynamics.What is the best way to connect this ?Is simply lowering output level going to work ?Do I need a DI Box ?
  • Trenutno na sajtu   1 član, 0 Skrivenih, 145 Gosta (Pogledaj celu listu)
    449.8k
    markot
    markot
