Lemur Napisano Oktobar 11, 2016 Share #1 Napisano Oktobar 11, 2016 Dragi forumasi, Ovih dana sam nesto gledao ponudu kineskih DACova na ALIexpress-u, za neku razumnu cifru do 200 eur ili ti dve glave... Pa sam izdvojio sledece reprezentativne primerke https://www.aliexpress.com/item/Finished-DAC7-parallel-dual-WM8741-WM8805-CM6631A-AD627-Audio-DAC/2055162863.html?spm=2114.01010208.3.114.4wlMUn&ws_ab_test=searchweb0_0,searchweb201602_3_10056_10065_10055_10068_10054_10069_10059_10073_10017_10070_10060_10061_10052_10062_10053_10050_10051,searchweb201603_3&btsid=d5b60c19-f07c-472f-9b59-dac42c8cd4a6 https://www.aliexpress.com/item/Finished-aquarius-PCM1794-AK4118-OPA2604-Top-Audio-DAC-cl134/32247675937.html?spm=2114.10010108.1000013.2.6ZAFkz&scm=1007.13339.33317.0&pvid=87bba8e0-2a9b-428d-90f5-b712279167fb&tpp=1 https://www.aliexpress.com/item/TOP-AK4495-XMOS-ADUM-High-Speed-Digital-isolation-Asynchronous-USB-DAC-decoder/32697280470.html?spm=2114.10010108.1000013.7.KjiGCa&scm=1007.13339.33317.0&pvid=88312c3f-eb1e-4805-87de-57505484f9ec&tpp=1 https://www.aliexpress.com/item/Finished-CS8416-WM8741-OPA2134PA-Audio-DAC-L153-22-HL/32320592778.html?spm=2114.01010208.3.42.xCr5mk&ws_ab_test=searchweb0_0,searchweb201602_3_10056_10065_10055_10068_10054_10069_10059_10073_10017_10070_10060_10061_10052_10062_10053_10050_10051,searchweb201603_3&btsid=019918d4-51e8-49f0-ad7f-d5749ebf6252 Da li je neko mozda slusao nekog od ovih zmajeva ili ima neku predstavu kako ovo moze da zvuci Link to comment Podeli na ovim sajtovima More sharing options...
BokiTokiVoki Napisano Oktobar 11, 2016 Share #2 Napisano Oktobar 11, 2016 Ako je ikako moguće, rastegni se malo preko 200e, i sastavi JL Sounds DAC iz modula. (AK4490) I2SoverUSB+DAC pločice su 110e, napajanje 37e (bez trafoa), analogni deo sa 2XLME49710 je 52e. Opciono display i DRV603 filter board, kao i zaseban oscilator board. Nije loše obratiti pažnju da se ima posebno stabilisano napajanje za svaku pločicu. Kao što se vidi, osnovni deo, bez trafoa, kutije i konektora je 200e. Razlog što ovo preporučujem je što je Bugarin odradio sve kako bog zapoveda, po data sheet proivođača, a Kinezima se nikada ne zna šta su smandrljali. Najčešće raščerupaju originalnu shemu da bi uštedeli, pa je i zvučni rezultat takav. Slušao sam jedan pomenuti AK4490, i to je veoma dobro. Ima solidnih kineskih uređaja, ali ko bi međ' aliexpress ekipom pronašao šta valja. Dobri su gotovi uređaji Audio-GD, ali to je već znatno veća cifra. Ko zna zbog čega. Link to comment Podeli na ovim sajtovima More sharing options...
mrcelavi Napisano Oktobar 11, 2016 Share #3 Napisano Oktobar 11, 2016 Koristim S.M.S.L. M8 i mogu toplo da ga preporučim, naravno onima kao ja, koji ne umeju da sastave nešto bolje. Usb DsD dac a izađe čini mi se oko 250 šuški. Link to comment Podeli na ovim sajtovima More sharing options...
Lemur Napisano Oktobar 11, 2016 Autor Share #4 Napisano Oktobar 11, 2016 1 hour ago, mrcelavi said: Koristim S.M.S.L. M8 i mogu toplo da ga preporučim, naravno onima kao ja, koji ne umeju da sastave nešto bolje. Usb DsD dac a izađe čini mi se oko 250 šuški. DC powered, na to mi se odma spusta... nivo raspolozenja Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Oktobar 11, 2016 Share #5 Napisano Oktobar 11, 2016 JLSounds mogu da ponesem na FAK Link to comment Podeli na ovim sajtovima More sharing options...
chakija Napisano Oktobar 11, 2016 Share #6 Napisano Oktobar 11, 2016 Kakav je u poredjenju sa Fikusom i onim drugim dacom sto imas? Link to comment Podeli na ovim sajtovima More sharing options...
mrcelavi Napisano Oktobar 13, 2016 Share #7 Napisano Oktobar 13, 2016 On 10/11/2016 at 10:00 PM, Lemur said: DC powered, na to mi se odma spusta... nivo raspolozenja Hebi ga, i meni se svidja Bugati, al gume su mu bezveze. Onda bratac zavališ 5x200 i vozi. Link to comment Podeli na ovim sajtovima More sharing options...
skrstic Napisano Oktobar 13, 2016 Share #8 Napisano Oktobar 13, 2016 On 10/11/2016 at 10:00 PM, Lemur said: DC powered, na to mi se odma spusta... nivo raspolozenja Pogledaj i ovaj DC powered uređaj. http://www.m2tech.biz/it/commerce/?mod=product&cat_id=1&product_id=53 Znam jednog što ima http://www.m2tech.biz/it/young.html koji je takođe DC powered uređaj i lepše zvuči od mog ak4459 kineza. DC powered uređaj znači da lakše možeš da unaprediš kvalitet dolazeće struje po meni. Link to comment Podeli na ovim sajtovima More sharing options...
mrcelavi Napisano Oktobar 13, 2016 Share #9 Napisano Oktobar 13, 2016 Ma ima SMSL i linearno napajanje u posebnom box-u, samo prelazi preko budžeta. Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Novembar 2, 2016 Share #10 Napisano Novembar 2, 2016 Interesantan all in one https://www.aliexpress.com/item/XMOS-ALIENTEK-D8-80W-2-Mini-Hifi-Stereo-Audio-Digital-Headphone/32583670076.html?spm=2114.01010208.6.7.qTLuyZ&s=p Link to comment Podeli na ovim sajtovima More sharing options...
crni. Napisano Novembar 2, 2016 Share #11 Napisano Novembar 2, 2016 ne zanimaju me uređaji lakši od bureka Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Novembar 2, 2016 Share #12 Napisano Novembar 2, 2016 Evo kako im izgleda proizvodnja Link to comment Podeli na ovim sajtovima More sharing options...
