IT razno.
Mikorist
pre 2 časa, zika reče
Ovo PayPal ima opciju plaćanja u 4 rate ???
Pa predivno . :thumbup:
  • 3 nedelje kasnije...
WWW.NATURE.COM
In the standard Si transistor gate stack, replacing conventional dielectric HfO2 with an ultrathin ferroelectric–antiferroelectric HfO2–ZrO2 heterostructure exhibiting the negative capacitance effect demonstrates ultrahigh capacitance without degradation in leakage and mobility, promising for ferroelectric integration into advanced logic...
COSMOSMAGAZINE.COM
An engineered crystal of hafnium oxide and zirconium oxide can lower the amount of voltage required to control computer transistors by 30%.
  • 2 nedelje kasnije...
Napisano (izmenjeno)
Ko bi rekao da će na Zapadu biti najveća zabrana slobodnog političkog mišljenja otkad je sveta i veka? A usput su dozvoljena najgora moguća javna i tajna ponašanja, totalni nemoral, svakojake perverzije, izmišljotine, falsifikati i lupetanja bez granica ali samo pod uslovom da nisu vezana za zvaničnu politiku i državne interese. Vrlo zanimljiv razvoj događaja nema šta. :punish:
Izmenjeno od NIXIE
  • 4 nedelje kasnije...
Audio Computer and HiFi Music Server Setup
WWW.24BIT96.COM
USB Audio Computer Setup - Configuration and build your own Realtime Audio PC for lossless and bit-accurate playback of High-Res Music Downloads. It's easy
Bitperfect MPD with ALSA for a Linux Audio PC System
WWW.24BIT96.COM
How to setup your HighEnd Audio PC with Music Payer Daemon (MPD) based on a low latency Linux with a Realtime Kernel for bit-accurate Digital Audio Playback
Bitperfect Mac - USB Audio Settings for OS X and Vox
WWW.24BIT96.COM
Easy step-by-step configuration of a bit accurate USB-Audio with Mac OS Vox. Turn your MAC into an Audio PC
Bitperfect Windows10 Foobar2000 - HiFi Music Server
WWW.24BIT96.COM
How to configure an Audio PC with foobar2000 and Windows7 to achieve bit-accurate playback with kernel streaming. USB Audio Settings for High Res Audio
  • 2 months later...
Citat
Bez prevoda, sinhronizacije i promotivnog perioda
Premda su korisnici iz regiona već na reklamnim materijalima mogli da pročitaju sitna slova na kojima piše da je u pitanju servis isključivo na engleskom jeziku — “Disney+ is a service on English” –  do kraja godine je najavljeno uvođenje titlova na srpskom, hrvatskom, slovenačkom i bugarskom jeziku. Isto važi i za sajt Disney+ platforme, koji je u potpunosti na engleskom jeziku, a tačan datum uvođenja sadržaja na drugim jezicima još uvek nije poznat.
Pretplatnici iz Srbije, Hrvatske, Slovenije i Bugarske neće imati priliku da uživaju u promotivnom periodu po kome, prilikom prvog pokretanja usluge, 12 meseci korišćenja plaćaju onoliko koliko bi platili osam, kao što je slučaj u, recimo, Poljskoj i Grčkoj.
WWW.NETOKRACIJA.RS
Od ovog meseca, korisnici iz Srbije i regiona imaju priliku da se pretplate na Disney+ striming platformu, ali uz određena ograničenja.
  • 1 month later...
