чика-Брка Napisano Maj 12, 2015 Share #1 Napisano Maj 12, 2015 Audio Technica AT 727 Sound Burger tako se zove uredjaj, to jest gramofon. moja gospodja ga krstila "beba gramofon". stigao pre oko nedelju dana, danas ga tek pustio u pogon. nisam imao ispravljac 5V. proban na bakterije, cisto da vidim dal radi. iako izgleda naoko veoma jadno, kad sam malo pogledao po jebeju se prodaje za besne novce. kad kazem besne, besne za njega, to jest takav uredjaj, sokocalo. jedna pogodnost - ima sopstvenu riaa, milina. ulaz za 2 para slusalica - valjda za piknik - dvoje mladih - jebem li ga. zvucno je na mojoj lestvici od 1-10 da kazem 7. za takvo sokocalo koje jadno izgleda, svira neocekivano dobro. za kraj - adapter za ploce na 45 obrtaja je ujedno i clamp Link to comment Podeli na ovim sajtovima More sharing options...
чика-Брка Napisano Maj 12, 2015 Autor Share #2 Napisano Maj 12, 2015 SpecificationsPlatter: 90mm aluminium die cast Motor: electronically controlled dc motor Drive system: belt drive Speeds: 33 and 45rpm Wow and flutter: less than 0.2% Signal to noise ratio: 50dB Tonearm: dynamically balanced type Cartridge: dual magnet type Tracking force: 2.0g Output voltage: 4.5mV Stylus: ATN-103 Amplifier section: 30 to 25,000Hz, 110mV (line out) Dimensions: 290 x 99 x 65mm Weight: 1.2kg (not including batteries) Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Maj 12, 2015 Share #3 Napisano Maj 12, 2015 a, ostavio si mu audiofilsku prašinčugu namerno, priznaj Link to comment Podeli na ovim sajtovima More sharing options...
Walter Napisano Maj 13, 2015 Share #4 Napisano Maj 13, 2015 Ima toga pod raznim imenima, pa i kod nas na oglasima: dual: http://www.kupujemprodajem.com/Dual-Portabl-PRP-5-Portable-Turntable-9392371-oglas.htm?filter_id=30219690 saba: http://forum.rollingstone.de/showthread.php?11388-Vintage-Hi-Fi&s=9e8b8d70ee016e0083bc54bebc376bbd&p=1541037&viewfull=1#post1541037 audio tehnica: http://www.audioscope.net/audio-technica-sound-burger-turntable-p-2147.html He he "sound burger" (simpatičan naziv) Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Maj 13, 2015 Share #5 Napisano Maj 13, 2015 zvucno je na mojoj lestvici od 1-10 da kazem 7. ...a da ti nije neko malo skratio lestvicu sa gornje strane? (meni zvučno moj Technics 1210 sa izmeštenim napajanjem i Denon DL-130R negde na 8 od 10... - ispade da sam bacio pare neviđeno ako taj čizburger od grebofona tako dobro svira da zavređuje tek malo manje od kombinacije koju ja imam) Link to comment Podeli na ovim sajtovima More sharing options...
...sam se banovo Napisano Maj 13, 2015 Share #6 Napisano Maj 13, 2015 ...a da ti nije neko malo skratio lestvicu sa gornje strane? (meni zvučno moj Technics 1210 sa izmeštenim napajanjem i Denon DL-130R negde na 8 od 10... - ispade da sam bacio pare neviđeno ako taj čizburger od grebofona tako dobro svira da zavređuje tek malo manje od kombinacije koju ja imam) Možda mu je to "lestvica" za digitalije (zato je gore skraćena) a grebofon/analogija kolko god da košta je UVEK bolja ...ono što mene zanima jel u ručici VanDenHul kabel? Link to comment Podeli na ovim sajtovima More sharing options...
чика-Брка Napisano Maj 13, 2015 Autor Share #7 Napisano Maj 13, 2015 moze da se smeje ko god hoce ili da neveruje, ali je istina. mali tugomir svira veoma, veoma lepo. po mojoj lestvici stvarno 7/10. sto se tice pravih gramofona, 1210 mi nikad nije bio "my cup of tea". mislim (po meni) da je malo bezdusan. moze da se napravi da svira veoma lepo, ali pomalo bezdusno. od boljih dramofona koje sam imao, i do AT 727 i inace gledano, najmuzikalniji je bio ubedljivo Transcriptor, sa originalnom Vestigial ruckom i glavom. imao sam i slusao tusta i tma gramofona ali kad budem nasao zvucno isti ili bolji, idem u penziju. kao sto sam nasao zvucnike, tako i za gramofon - kad nadjem - ende. ima na vidiku, ali bice o tome kad nadjem malo vremena. potencijalna kombinacija za penziju je mozda Linn. Link to comment Podeli na ovim sajtovima More sharing options...
zika Napisano Maj 17, 2015 Share #8 Napisano Maj 17, 2015 Odakle počeše da stižu u naletima? Link to comment Podeli na ovim sajtovima More sharing options...
zika Napisano Maj 17, 2015 Share #9 Napisano Maj 17, 2015 Evo ga još jedan... Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Maj 17, 2015 Share #10 Napisano Maj 17, 2015 Evo ga još jedan... Ma to je isti taj Link to comment Podeli na ovim sajtovima More sharing options...
zika Napisano Maj 17, 2015 Share #11 Napisano Maj 17, 2015 Ma to je isti taj чика-Брка je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
