Pojačavači sa SIT tranzistorima
prophet
да ми је да имадем....
мало је то Мико за билокакве лекове,иначе кичма се третира врло јефтиним лековима,
Диклофенацима,нимулидима,бруфенима уз неизбежан српски универзални лек-бенс...
да ми је само мало....
majdo, oš pazariš par komada vfeta i praktično probaš?
razvodniste bre temu stim šta-sve-ne-valja i šta-bi-bilo-kad-bi-bilo
Pa zasto da ne?
(Cujemo se ti i ja, pa da se u zdravlju i vidimo...)
  • 2 nedelje kasnije...
mosfet
Mea culpa... Juče sam nešto radio i ovo primetio i, naravno, pogrešio...
Ko zna gde mi je glava bila, za pamet znam da je nema...
Povuklo me je, tokom čitanja, to što je tu i FW SIT...
Izbrisaću čim pročita{te,ju}...
  • 10 months later...
Interesantna saradnja Pass i Sony povodom 40 godina V-fet:
http://blog.sony.com/press/sony-demonstrates-pass-laboratories-40th-anniversary-commemorative-vfet-amplifier/
Sony’s VFET devices, also known as Static Induction Transistors (SIT), were smaller, less costly and much more efficient than conventional vacuum tube designs and were widely acknowledged for their “Triode-like” sound quality. Additionally, these transistors serve as extremely fast switching devices, which enabled Sony to introduce the first high-powered Class D audio amplifier in 1976.
This exclusive Pass Laboratories commemorative amplifier employs complementary matched pairs (2SK82 and 2SJ28) of Sony VFETs, which were in storage for nearly 40 years. The mono block amp operates in Class A mode, with a balanced circuit from input to output and no feedback required. The amplifier also includes a highly regulated stable power supply, which enables it to achieve 250 watts peak power into a 4 ohm load, with relatively low distortion (less than 2%).
nema cene , jer nece biti ni serije
ovo je one off , demonstarcija sile
a mozda i kuka ovima iz Sony-ja , ne bi li obnovili proizvodnju VFETs
BB - ovi amps imaju te SONY-je kao source follower - nemas dovoljno da napravis bolestinu kao ovo , a veca je korist da se napravi amp koji ce koristiti njihov gain .......... bas kao u Ćaćinom ampu - sources to rails , a ne sources to out
