Mikorist
Kafanica . . .
Možda će nestanak struje imati pozitivan uticaj na Srbiju u pogledu problema zvanog " bela kuga "Ruse boli uvce za ovu kataklizmicu u najavi pošto njima sve ide na gas.
Podeli ovu poruku
Link do poruke
Saću bre sve da vas banujem i zaključam sve ovakve topike!!!
:house14:
Podeli ovu poruku
Link do poruke
ako sve banujes , ne moras nista zakljucavatisamo ugasi svetlo pre nego izadjes:serbvidkakisicl0:
Podeli ovu poruku
Link do poruke
:house14:
Ti ban-uj, ja ću da zaključavam topic-e...
Da stignemo na vreme... Dok ne nestane struja...
Podeli ovu poruku
Link do poruke
I onda cemo pricati price kako smo imali nesto sto se zvalo internet, slusali full-range zvucnike, a neki ekscentrici su cak tvrdili da mogu cuti razliku izmedju kablova... :buehehe:Ma smislicemo mi vec nesto. Evo Stein ima super potkrovlje pa bi kod njega mogli drzati golubove pismonose :buehehe: A onima sa velikog Diyaudio ce biti teze, nema takih' golubova da prelete okean :)
Znači na vreme da registrujem firmu "Ikaro-expres"Prevoz FR drajvera do 5" :sarcastic_hand::sporty095_2:
Podeli ovu poruku
Link do poruke
X-ray plot sunca
Postavljena slikaThe scale measuring their strength has three general categories – Class C, Class M and Class X – with Class X flares being the most powerful.
The GOES X-ray Flux plot contains 5 minute averages of solar X-ray output in the 1-8 Angstrom (0.1-0.8 nm) and 0.5-4.0 Angstrom (0.05-0.4 nm) passbands. Data from the SWPC Primay GOES X-ray satellite is shown. As of Feb 2008, no Secondary GOES X-ray satellite data is available. Some data dropouts will occur during satellite eclipses.
trenutno je M class
kad bude X100 (1859 flare) sto je daleko iznad ove skale gde je Klasa X - onda mozemo da se pozdravljamo sa uredjajima na struju....
ko ne zna sta je EMP ima ovde:
http://en.wikipedia.org/wiki/Electromagnetic_pulse
Podeli ovu poruku
Link do poruke
Older, vacuum tube (valve) based equipment is generally much less vulnerable to EMP than newer solid state equipment. Soviet Cold War–era military aircraft often had avionics based on vacuum tubes due both to limitations in Soviet solid-state capabilities and a belief that the vacuum-tube gear would survive better. :tongue10:-----------------nikakva nuklearna bomba ne moze da se poredi sa velicinom i jacinom Sunca.mi smo samo 3 pikavac od njega :sarcastic_hand:
Podeli ovu poruku
Link do poruke
Pozdrav od KUB-ovca...
Podeli ovu poruku
Link do poruke
