E ovako , zanima me dali ima veze raspored kablova u toku signala od izvora do zvucnika, pri tome ne misleci na kvalitet nego na tip provodnika.
Znaci, jeli bitno da se ispostuje licna celim tokom ili je negde bolji pun presek i tako dalje...zvuci elementarno ali mi je palo napamet pa reko da priupitam.
Kod mene je recimo ovako (ako se secam):
DAC interno
LICNA ==> interkonekt
LICNA ==> Preamp interno
PUNpRESEK ==> interkonekt
LICNA+PunPresek ==> Amp interno
LICNA i zvucnicki
pun presek za bas i licna za visoke
Eto, pa zanima me jel ti skokovi signala sa PP na LICNE kroz sistem i obrnuto dovode do nekog gubitka ili nezeljenog efekta?
pozdrav
“Education develops the intellect; and the intellect distinguishes man from other creatures. It is education that enables man to harness nature and utilize her resources for the well-being and improvement of his life. The key for the betterment and completeness of modern living is education. But, ' Man cannot live by bread alone '. Man, after all, is also composed of intellect and soul. Therefore, education in general, and higher education in particular, must aim to provide, beyond the physical, food for the intellect and soul. That education which ignores man's intrinsic nature, and neglects his intellect and reasoning power can not be considered true education.”
